Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - running different gear ratios in a mudd bogger
Old 05-17-2012, 05:31 PM
GMCBEAST's Avatar
GMCBEAST GMCBEAST is offline
Originally Posted by GMCBEAST
How come you can't run same ratio? My best friend run's mud bogs down in FL, we grew up around mudding and drag racing and I can tell you I've always been advised not to stagger gear ratio's and the guys who do always use a smaller tire on the numerically lower number side (4.10's in your case) for weight saving on the front end so they can "skip" across the mud easier. And like Cobalt said, stay off pavement if you do decide to do this!
Sorry Cobalt, meant solid ground as well as pavement, don't understand why I can't edit sometimes.
