running different gear ratios in a mudd bogger - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2012, 09:57 PM
inquiring_mind2's Avatar
a shade tree mechanic
I am wanting to run different gear ratio's in my jeep. I use it strictly for mudd boggs. I was wondering if I could run a 410 gear and a 488 gear, I will have the same size tires. I was going to run a 488 and a 513 gear but silly me forgot to order a different carrier to handle that numerically high of a gear. any help would be greatly appreciated
Old 05-17-2012, 01:20 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Use the higher ratio (lower number) in the front. Whether the split you want to use is too much or not I have no idea. Be sure to unlock it or pull the front d-shaft before driving on solid ground.
Old 05-17-2012, 04:35 PM
GMCBEAST's Avatar
How come you can't run same ratio? My best friend run's mud bogs down in FL, we grew up around mudding and drag racing and I can tell you I've always been advised not to stagger gear ratio's and the guys who do always use a smaller tire on the numerically lower number side (4.10's in your case) for weight saving on the front end so they can "skip" across the mud easier. And like Cobalt said, stay off pavement if you do decide to do this!
Old 05-17-2012, 05:31 PM
GMCBEAST's Avatar
Sorry Cobalt, meant solid ground as well as pavement, don't understand why I can't edit sometimes.
gear ratios coyote74 Transmission - Rearend 13 07-27-2008 06:11 AM
gear ratios american muscle rulz Transmission - Rearend 0 07-07-2007 03:38 PM
rear motor mudd bogger switch from front tony echeman Hotrodding Basics 3 09-15-2006 07:31 PM
rear motor mudd bogger switch from front tony echeman Introduce Yourself 1 09-11-2006 11:13 AM
gear ratios Blag Transmission - Rearend 2 02-09-2003 04:59 AM
