Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Running an engine in "cold" weather with no manifolds.
Old 11-19-2012, 04:52 PM
against all odds against all odds is offline
Banned User
Originally Posted by bondo View Post
Ayuh,.... My question is,... Why would you Want too..??
Well, to put to rest once and for all the whole, you'll warp a valve thing.....
Originally Posted by Mr. P-Body View Post
Old wives are pretty smart sometimes. It is absolutely true, allowing "cold' (ambient) air to get to hot exhaust valves (the "open" ones) WILL warp them. I have seen a Harley valve bend so bad it broke when he tried to fire the engine again. It makes perfect sense. The air approaches the hot valve from one direction, cooling one side much more rapidly than the other.
When we "run engines in", and use only the manifolds, each of us are ready to stuff a shop towel into the manifold immediately upon shut-down. I would never consider firing an engine without at least manifolds.
Like here, we have first hand anecdotal evidence of such an occurrence. Perhaps a first hand "mythbusters" type experiment is really necessary?
