Running an engine in "cold" weather with no manifolds. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2012, 07:25 PM
Banned User
Let's discuss, and get into it whole-hog once and for all, the whole running and engine with no manifolds in cold weather thing.
b) with manifolds but no further exhaust pipes.
Old 11-16-2012, 07:35 PM
vinniekq2's Avatar
what about it? probably would disturb the neighbours
Old 11-16-2012, 07:36 PM
As a teenager (which was a looong time ago), I was told that running an engine with only the exhaust manifold could result in warped valves, because after you shut it off the valves would cool too quickly. I never really knew if that was true or not. I just remember being told about it. However, I never had a problem with warped valves on any engine.
Old 11-16-2012, 07:47 PM
poncho62's Avatar
Wiki Edits: 5
Old wives tale
Old 11-18-2012, 04:10 AM
bondo's Avatar
Ayuh,.... My question is,... Why would you Want too..??
Old 11-18-2012, 07:10 AM
Had a friend back in the 80's who let his 64 chevelle sit outside with no manifolds on it.Valves rusted to the seats and engine wouldn't turn over.He sold me the car and I soaked it with Kroil and it freed up!
Old 11-18-2012, 09:09 AM
Old wives are pretty smart sometimes. It is absolutely true, allowing "cold' (ambient) air to get to hot exhaust valves (the "open" ones) WILL warp them. I have seen a Harley valve bend so bad it broke when he tried to fire the engine again. It makes perfect sense. The air approaches the hot valve from one direction, cooling one side much more rapidly than the other.
When we "run engines in", and use only the manifolds, each of us are ready to stuff a shop towel into the manifold immediately upon shut-down. I would never consider firing an engine without at least manifolds.
FWIW
Jim
Old 11-19-2012, 04:52 PM
Banned User
Well, to put to rest once and for all the whole, you'll warp a valve thing.....
FWIW
Jim
Like here, we have first hand anecdotal evidence of such an occurrence. Perhaps a first hand "mythbusters" type experiment is really necessary?
Old 12-02-2012, 03:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by poncho62 View Post
Old wives tale
Of course it is.
I watch oval track races at the Taft track (Orlando Raceway) back in the '60s that had many low-buck race cars that used absolutely NO exhaust manifolds at all- nothing, zip, zilch, nada.
These guys were not front runners, mind you- they were in it for the fun of it. But these same guys- running the same engines- were there week in week out, for the entire season, and there's no reason to think these same engines weren't run for several seasons, and know what? Nary a warped valve to be seen.
Old 12-02-2012, 12:26 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Completely untrue. Keep in mind the components in contat with combustion are are feeling 1200 degree exhaust gases. Just because our subjective interpretation of 70 degrees is "warm" and 30 degrees is "cold" doesn't mean the stainless steel in your valves is going to notice. 40 degrees compared to 1200 is a drop in the bucket, and probably won't make almost any difference in how long it takes the valves to reach ambient temp.
K
The Following User Says Thank You to killerformula For This Useful Post:
cobalt327 (12-02-2012)
Old 12-02-2012, 12:51 PM
bigdog7373's Avatar
Of course it's fast
At minimum use manifolds. No way the cold air is gonna come backwards up the manifolds at hit the valves. I wouldn't run with no manifolds, although nothing would probably happen i wouldn't want to risk that the "myth" actually be true.
Little test with Rust-o-lium "Cold galvanize compound" and weld thru primer. MARTINSR Body - Exterior 13 02-15-2010 07:10 AM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 12:44 PM
cold weather running with Edelbrock JUSTINH Engine 10 02-25-2004 03:05 PM
Advice? Truck running very bad in cold weather. firewood Engine 8 11-10-2003 05:30 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
