Running engine volt charge reading goes down - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2010, 04:55 PM
Hello guys I have something going on with my charging system on my 96 chevy s10. I have a 350 SBC in this thing carbureted and no electronics except my HEI distributor and basic factory stuff and no emissions hookups or anything else.
I have replaced everything on the truck since I got it with a new battery that is only 6 months old and the alternator is brand new as well. Also all battery wires are new as well from positive wire to all the ground wires. Ok here is what's going on. When first starting up my truck its charging at 14.6 volts and will stay that way for a while. Then after a certain amount of time it will go down to about 13.6 but no lower.
I have checked everything with my volt meter and I am not understanding why this is happening. This happened with the alternator that I got new from last fall and I had problems with it vibrating really bad at higher rpm's and breaking the bolt twice that goes into the cylinder head. I brought it too the auto store and they replaced it with a new one and it is still doing this.
That was not why I brought the alternator back but the previous one you could hear the bearings grind in it which was causing the vibrations at higher rpm. I have two volt gauges one being the original factory one on the dash and a mechanical gauge set I have. Factory one always reads less but I am having no problems with charging running power accessories etc for the time being. I am running a 65 amp alternator if that helps.
Now this happens with me running nothing power wise and if running my lights it goes down just a hair but lights are still nice and bright and checking my battery with vehicle not running its always about 12.6. So is this normal as engine has got good and warm? Belt is nice and tight and everything checks out good as far as my hookups goes. Have been told if everything is working good then don't worry about it but I guess I want to know is this normal.
Thanks Eric
Old 08-10-2010, 05:35 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I'd be a little concerned about the 14.6 as well as the 13.6, should be 13.8 to 14.2. It's probably either a variance in your voltage regulator, or in the gauge(s). Have you checked it with a DMM, to be sure your gauge(s) are accurate?
Old 08-10-2010, 05:42 PM
Yes I did check this will a volt meter and what I am assuming you mean by DMM ( digital multi meter ? ) what I mean by volt meter is a voltage meter that checks all different type of electrical voltage from automobile, home use and many other things.
I am new to using one of these but hooked it up and it comes out as I stated above. The factory gauge is a little off but my mechanical gauge is dead on and read's the same as the the hand held digital multi meter. It starts off about 14.6/14.5 then goes down to about 13.6 after its been running a while.
Eric
Old 08-10-2010, 06:14 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Its supposed to drop down, after your battery gets charged back from the power it used to start the car....your alternator charges it back and your voltage regulator cuts it back when it needs to.
Old 08-11-2010, 04:30 PM
Ok thanks for the info. I did not know it would do that so I am in good shape then since it's all charging normally. I guess it might have did this all this time and I did not notice it.
Thanks guys
Eric
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Chevy Engine keeps running smokey626 Engine 21 09-26-2009 10:57 PM
causes for high volt meter reading +16 ! wheel-7 Electrical 3 05-11-2008 04:13 PM
bad running engine roycecas1 Engine 7 08-18-2006 06:37 AM
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 12:29 PM
