Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Running fuel lines like this?
Old 12-18-2008, 05:48 PM
tomslik tomslik is offline
3rdmember
here's something else.
use high pressure F.I.hose.
why?
if something should go wrong (blockage, regulator goes nuts,etc) the pump WILL make 75 psi of fuel pressure and will burst the regular fuel hose.
use it on BOTH the feed and return lines...
