Running fuel lines like this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2008, 03:28 PM
DarknessSpawned's Avatar
God Of Lightning
Just trying to makesure I have it right..... Will be using stock in frame
tubing as it says and aftermarket fuel hose......
Old 12-18-2008, 04:21 PM
I would relocate the vapor canister closer to the tank to reduce engine bay clutter. The second inline filter closer to the carb probably isn't necessary. Looks good though
Old 12-18-2008, 05:48 PM
3rdmember
here's something else.
use high pressure F.I.hose.
why?
if something should go wrong (blockage, regulator goes nuts,etc) the pump WILL make 75 psi of fuel pressure and will burst the regular fuel hose.
use it on BOTH the feed and return lines...
Old 12-18-2008, 06:31 PM
God Of Lightning
why?
Alright... And also how would that effect my holley if that were to
happen?
Old 12-19-2008, 02:59 AM
3rdmember
you have fuel spraying on a hot motor and you're worried about the carb?!?!?!
i'd be carring a BIG fire extinguisher and a LOT of insurance....
seriously...
anyway, the carb WILL flood, dumping mucho fuel into the intake.
you know the rest...
Old 12-19-2008, 07:55 AM
Do you have to use the same vapor canister? K&N Makes a tiny little air filter I have used on RC cars. What about putting that on in an out of the way spot?
Old 12-19-2008, 09:44 AM
Cape Cod Bob's Avatar
Why not use a low pressur fuel pump and eliminate that danger.
Old 12-19-2008, 11:54 AM
God Of Lightning
seriously...
You took it the wrong way.
I figured there would be gas spraying if the lines busted... BUT
Just wondered if the carb would be damaged if I ran F.I. lines that didnt bust
and the pressure regulator failed.
So just calm down my man.
Old 12-19-2008, 11:55 AM
God Of Lightning
I was gonna relocate the stock one to the tank area.... The tank
is being relocated.....
Old 12-19-2008, 11:58 AM
God Of Lightning
I will be down the line. Not too far down the line... But not
right now either. For now this way is a tried and proven way
from what all Ive seen so Im not THAT worried but im also
keeping a close eye on things... Im not running a different
pump until I get a 20 gallon cell. Unless my pump failed before
then id just get a holley RED instead of replacing the stock.
Old 12-19-2008, 05:48 PM
3rdmember
i'm plenty calm.
i'm not the guy running for the extinguisher
i doubt it would do anything to the carb from excessive fuel pressure.
the carb burning up in the fire might be an issue
f.i. hose ain't hard to come by, ain't as cheap as the regular stuff, but that's what I'd do...
run as much hard line as you can and then use the f.i. stuff...
Old 12-20-2008, 02:17 AM
God Of Lightning
i'm plenty calm.
Im installing a sprinkler stystem in place of the windshield wiper
fluid that is set to go off when the temp gets to fire hot like the
kind thats right above your office space over der.
...how bout it.
Old 12-20-2008, 03:42 AM
Jake_Dragon's Avatar
Last journal entry: New Carb
My Vette has 3 regulators, one to drop the initial pressure down and then 2 right before the carbs to set the correct pressure for them. If the main regulator fails the second set should catch it.With the return line it should just circulate back to the tank if the first regulator fails open.
You could try something like that.
Old 12-20-2008, 05:43 AM
3rdmember
...how bout it.
yeah that might work,but don't use washer fluid.
that's flammable and yes, i know THAT by experience.
btw, my "office"doesn't have a fire system, just an extinguisher right next to my toolbox
seriously,use the high pressure stuff.
hate to see the post that says:"well my car burnt up"
Old 12-20-2008, 09:00 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
I see you have a 88 s 10 , so i assume your keeping the stock F/P in the tank , and it was tbi so your only gonna be running 15-17 psi maxs so no real worries about high pressure FI fuel line.
Sunfire, died and wont start back, fuel pump is running, no gas getting to filter jordan2011 Engine 6 04-21-2008 06:01 AM
Too many fuel lines? ffcagle34 Engine 5 06-12-2007 08:29 AM
Headers hitting fuel lines! Please Help 85CHEVY Engine 17 09-02-2005 10:22 PM
Carb size to small???? brainsboy Engine 50 08-14-2005 04:04 PM
Running brake, electrical and gas lines with a boxed frame? jimmy p General Rodding Tech 13 06-27-2003 08:44 PM
