Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Running a Holley...read this!
Old 12-10-2012, 08:26 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
I just found a source that confirms that ALL premium fuel sold in Alberta is ethanol-free ... as long as the data is still current.
Pure-gas.org
(This site lists locations by US state as well.)
Further reading (elsewhere) says that ethanol is a big "no-no" in a marine environment as well as in 2-cycle engines in general.
Also worthy of mention is that NGK says premium fuel might be hard on sparkplugs. I wonder if that statement was made prior to ethanol blending?
High Octane > Problem Solver or Problem Creator?
If OEM vehicle/engine specifications state the use of high octane, or specify an octane level rating to use, this must be complied with to prevent engine component damage. The use of lower octane than recommended can cause detonation and engine damage. The use of higher than recommended can cause fouling problems, even more so in the cooler climates.
The reason for this is the higher the octane the slower the burn rate which either cools or heats the combustion chamber outside of OEM specifications. This can be especially prevalent in cold climates or 2 stroke applications where the use of the incorrect fuel leads to a high failure rate on spark plugs! Always comply with the specified fuel rating for your vehicle.
Note: Premium fuel is considered 91 or 92 by OEM
Ethanol Free Premium Coalition New York Is Not A Mandatory E10 State
Prohibit Ethanol Blending In All Premium Unleaded Gasoline
Every mandatory E10 state has exemptions to their blending law, because there are a number of piston engine applications that should not, and some that cannot, use ethanol blended gasoline. Unfortunately the exemptions are not uniform. They vary from only one exemption in Washington, aircraft, to a universal exemption of premium unleaded in Missouri. All states exempt aircraft usage, but most states like Oregon and Washington make it almost impossible to get unblended gasoline. Oregon is the only state that allows for unblended regular and premium gasoline for the exemptions, and then makes it almost impossible to get any unblended gasoline. All other mandatory ethanol states just allow clear premium unleaded gasoline for the exempted classes.
The following piston engine applications should not use ethanol blended gasoline:
■ Any 2 cycle engine used in tools, watercraft, snowmobiles, etc., or small 4 cycle engines.
■ Any engines used in an emergency stationary engine application like a generator or a pump, especially in a humid climate.
■ All watercraft. Ethanol blended gasoline should never be used in a marine environment.
■ Antique and classic cars and classic motorcycles.
■ All aircraft.
All of these users must be able to get ethanol free (E0) gasoline. If you live in a state without a mandatory ethanol blending law, you have no exemptions, ethanol will eventually be blended into all of your unleaded gasoline and there is no requirement in EISA 2007 to label gas pumps with ethanol content.
All of this mumbo-jumbo comes to one thing.
I can see the day coming where the only place we can buy ethanol-free gasoline will be your local airport (or an av-gas distributor)
