Running ISO 32 in a powerglide??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2010, 10:18 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
My machinist was telling me about running ISO 32 hydraulic oil in his powerglide. Anyone do this and have success with it? What are the advantages of doing it?
Old 02-25-2010, 02:57 AM
SSedan64's Avatar
Lots of racers use Hydrauilc fluid in their Trans. It's cheaper. Most recommend a quart or 2 of regular Trans fluid to add some tint to it for level checking and finding leaks.
Old 02-25-2010, 05:01 AM
trans fluid is hydraulic fluid with dye and detergents in it, used to pick it up at the blending plant .
Old 02-25-2010, 06:20 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The main problem with use of hydraulic oil used in equipment is there are no proper additives to control moisture and other related stuff inside the trans.
In a race only application , this is not much of a problem since the service life of a race trans is shorter. As an eggzample in a drag race application the trans oil should be changed every 20 - 30 passes. A trans brake builds heat very rapidly , this is hard on the oil.
If you run a high horse power car ( over 1,000 hp) the trans oil should be changed after each race weekend , the pan dropped and look for debris
Old 03-02-2010, 07:42 AM
Listen and Learn
Wiki Edits: 7
are the only benefits to this being that its cheaper. Or is there any hp gain?
wiki: What seats will fit a '32 Ford? Jon Interior 2 05-24-2008 08:49 PM
32 Ford transverse spring questions.. F&J Suspension - Brakes - Steering 4 04-17-2008 08:45 PM
32 Bantam Powerglide MISFITZ Transmission - Rearend 6 09-10-2007 03:47 PM
Carb help, running rich ! xxllmm4 Engine 4 03-09-2007 02:43 AM
32 ford running boards graham Body - Exterior 1 11-08-2002 08:29 PM
