running new brake lines on my 1949 chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2011, 12:30 PM
i have a 1949 chevy pickup with a 1969 nova front and rear end. i want to run new lines all the way. do anyone have any suggestions
Old 08-06-2011, 12:39 PM
cool rockin daddy's Avatar
brake lines
Your best bet is to buy a tubing bender and flare tool and bend your own.
There are pre-bent lines available from Classictube or finelines for the Nova front end and rear but in between on the '49 Chassis is the problem. Look those two up on the net and give them a call. They might have a solution.
Old 08-06-2011, 12:47 PM
ok thanks for the brake line help
Old 08-06-2011, 02:08 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
don't forget the master cylinder you want to upgrade the whole system if you have room for the booster you can use power brakes if you get everything front and back for the nova you will only have to make the one front to back line as tbrown said.
Old 08-06-2011, 02:42 PM
I did a complete system on my 55 210 master to the wheels and bought the lines at NAPA, they have a big selection to choose from and I didn't have to cut or flare any of it. The total cost was less than a double flare tool.
Old 08-06-2011, 04:36 PM
ogre's Avatar
the 'Duracell Project'
i like hero's thought on this. unless you go stainless.
a cheap flare tool will drive you crazy with slipping.
Running new brake lines 51 Leadsled Suspension - Brakes - Steering 8 06-12-2011 04:46 PM
1949 ford f1 brake lines replacement drsergio Suspension - Brakes - Steering 4 11-06-2008 08:45 PM
Running brake lines? badriand Suspension - Brakes - Steering 4 06-01-2007 04:59 PM
Running brake, electrical and gas lines with a boxed frame? jimmy p General Rodding Tech 13 06-27-2003 08:44 PM
Running brake lines Will's41 Suspension - Brakes - Steering 11 12-29-2002 06:28 AM
