Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - running new fuel lines?
Old 02-26-2006, 08:32 AM
jcarter's Avatar
jcarter jcarter is offline
What are you guys doing for fuel lines?I have to make up a complete new line . Can I run rubber fuel line all the way down the side of the frame,if it is well secured or does it have to be steel?What type of steel tube would you use?What id. would I need? Engine is a 350 gm. 300hp. with 600cfm carb. Thanks Jim.
