Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - running new fuel lines?
Old 02-26-2006, 09:19 AM
1939P7 1939P7 is offline
thewrongshop@yahoo.com
Originally Posted by jcarter
What are you guys doing for fuel lines?I have to make up a complete new line . Can I run rubber fuel line all the way down the side of the frame,if it is well secured or does it have to be steel?What type of steel tube would you use?What id. would I need? Engine is a 350 gm. 300hp. with 600cfm carb. Thanks Jim.
I wouldn't go with rubber line all the way, but I know a friend
that did and he used fuel injection line. I did my project with steel
tubing and fastened it securely when the body was off, that made it
a bit easer.
Size of line for a V8 minimum for a 4BB 3/8", I say unless your
going Pro Street.
