that did and he used fuel injection line. I did my project with steel tubing and fastened it securely when the body was off, that made it a bit easer. Size of line for a V8 minimum for a 4BB 3/8", I say unless your going Pro Street. |
I always run hard lines for Fuel, brake and transmission fluids..... Not hard to learn and is sort of FUN, once you learn it and have a few tools... ![]() I get all my tools and line clamps from Ray Godman......
Re: running new fuel lines?
If by chance you ever wanted to see what she'll turn in the 1/4 , the NHRA rules state that you can not have more than 12" of rubber hose total . !
Hi
Now I have a question, if you run steel lines down the frame how do you avoid not having more than 12" of rubber total counting from the tank to the fuel line and from the frame to the line to the carb. I'm old and don't think straight so please give me a minute and answer this. 30dee |
3 inches.........line to the tank
2 inches .......line to the fuel pump 3 inches ......line to th carb If you want rubber..... Most racers use braided line with AN fittings .....I do when I can...
Personally I do not want any rubber line on the pressure side of the pump. If it's a mechanical pump it is hard line from the pump to the filter to the carb. Only rubber is from the fuel line to the pump intake, 6" at most.
Vince |
You need about 4" from the tank To the 3/8" hard line. The steel line can run all the way to a mechanicals pump , where it can go in solid or use 3 more inches of rubber . From the pump to the carb you can go solid all the way , that leaves about 5" to play with HA HA , Or you can use 2&1/2" from the pump back to hard line and then from the hard line to the carb. You'll get the idea |
Or use braided line with AN fittings.....to make re-jetting the carb easier...
Steve |
You can use lengths of standard brake line also. Most stores carry it in five foot lengths, so a junction will be needed in the middle. Just cut one end off and slip the hose on. There's no pressure on the suction side unless you have a rear mounted electric pump. I'm running EFI with 39 psi on the lines, so I put a little silicone on the end and push the rubber hose about an inch up -- enough to get two clamps on. Never had a leak, though two clamps might be a little over kill. Better over kill than killed though...
| Recent General Rodding Tech posts with photos |
| aluminum fuel lines ? | Vortech 4.3 | Engine | 7 | 02-14-2006 08:27 AM |
| 1960 corvette rochester fuel injection | ratlover | Engine | 2 | 09-27-2005 05:43 PM |
| Carb size to small???? | brainsboy | Engine | 50 | 08-14-2005 04:04 PM |
| Fuel Tank Installation Plumbing Questions | Doc68 | Engine | 9 | 01-05-2004 06:20 PM |
| Running brake, electrical and gas lines with a boxed frame? | jimmy p | General Rodding Tech | 13 | 06-27-2003 08:44 PM |
