Running the plug wires under the headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2007, 04:56 PM
For my engine compartment, I'm running an extremely "clean" look, with a bare minimum of wires and hoses showing. Kind of an "engine floating in the compartment" look.
Is there anyone that sells a kit to run the sparkplug wires under the headers? I know it's not a look that everyone likes, but I'd like to give it a try.
Old 01-29-2007, 04:57 PM
Also, any pics of people running their wires this way would be greatly appreciated!
Old 01-29-2007, 05:02 PM
aka Duke of URL
The mid-eighties 305 TPI ran the wires as you describe, but has long since discontinued the brackets to hold the wires.
It is good for keeping them away from hot headers.
Old 01-29-2007, 05:07 PM
New Member
I am running mine the same way. I purchased brackets from Paragon Corvette parts. They only have one side available but right and left are close enough to use on either side. They have a diagram on thier web site on how the look. Hope this helps!
Old 01-29-2007, 05:17 PM
aka Duke of URL
Can you guide me to that illustration? It seems I am GM handicapped...
Old 01-29-2007, 05:24 PM
Yes, a link to the website page would be awesome.
Their webpage isn't the easiest to find things on!
Old 01-30-2007, 01:19 AM
Chevs with ramshorns ran the wires underneath with clips built into the heatshields. I've got some long 'under header' leads from IC&E ignitions here but no clips. Your heads should have small tapped hole between the cylinders and just above the block to mount some clips to. Even a/market dart and pro topline have these holes.Look at a 66 or earlier small block.
Old 01-30-2007, 10:44 AM
Are you running tubular headers or when you say "headers" are you referring to the cast iron sort? As stated above the old Chevy ram's horn manifold cars had the wires routed under the manifolds. There was a bracket on the rear of the block perpidicular to the bellhousing flange that held the 4 wires coming off the distributor and going to each bank. I also seem to recall that there were clips on the oil pan bolts (2 clips holding 2 wires each on each side of the engine) that also held the plug wires. I seem to recall running the front two plug wires under or around the engine mounts as well
Sorry for the huge picture size, but this shows the setup we have on the '67.
Old 01-30-2007, 10:51 AM
I'm running tubular headers, not cast iron like in your pics.
My headers also are NOT the block hugger type. There is a ton of room between the headers and the block to run the wires.
Unless I can find something really clean looking that is premade, I may try fabbing up some custom brackets from .090 aluminum.
Old 01-31-2007, 05:23 AM
aka Duke of URL
Here is my problem. 1986 IROC-Z 305 TPI. CHEV had the ign wires running akin to the above offerered illustration. Their purpose was to keep them away from the exhaust manifolds/AIR manifold(s) heat. I went to replace wires and the insulators were of course brittle. CHEV no longer makes the service parts...
Because of the AIR manifolds, everything I tried to suspend the wires above the engine were not feasible. I finally used loom clips as used on FORD 5.0L but this is not perfect (the studs are not long enough to hold proper torque on the rocker cover bolt holes.
If anyone has a method of neatly routing wires under the headers (SLP) please direct me to the source.
Old 01-31-2007, 06:41 AM
Irelands child's Avatar
This isn't under the headers but might be a way to consider. The looms are Made For You, the wires are Taylor 8mm 90 degree universals that you have to make up.
Dave
ID:	18081   Click image for larger version
Irelands child
Old 01-31-2007, 07:23 AM
KULTULZ,
Did your IROC have heat shields under the manifold like in the picture shown above? We've never had a problem with the wires burning or aging prematurely due to heat with that setup. Then again it's not really a daily driver either.
Old 01-31-2007, 10:07 AM
aka Duke of URL
Dave
Dave, I tried several systems as you have shown. They will not work as the Thermactor tubes are too close to the head at that area. I imagine that is why CHEV routed the wires under the origional exhaust manifolds.
What I wound up doing was using the system as used on the late FORD 5.0L and it works but I would like a better system. Someone has to have a system to use considering the OEM parts are no longer available.
Originally Posted by Kevin Varnes
KULTULZ,
Kevin,
What I did with this IROC was to go through the top end. It got stainless valves and stamped ISKY roller rockers. I then went through the TPI upgrading and keeping it emissions legal. It got SLP headers, low restriction cat and performance Walker exhaust. So far I have had no trouble with the plug wires but am concerned about the possibility of heat damage/spark breakdown. Also, the threaded stud part of the FORD stud (accepts wire loom separators) that holds the rocker cover down is not quite long enough to let me feel comfortable with the required hold down torque.
I just thought with all of the Stovebolt Freaks here that someone may have solved this problem as there are how many TPI 305/350's out there?
Let me see if I can find some past photos and I will post them to show what I have done. I have it down right now for a new set of injectors.
Thank You Guys!
Old 01-31-2007, 03:00 PM
RippinRon's Avatar
Check out this guys setup . Its not under the headers but its a clean install with cheap parts.
Old 02-03-2007, 08:44 PM
Well, I couldn't find anything that would work, so I had to fab up a couple of small brackets.
Ran one wire in a sheath under the engine mount, and made a bracket for each side.
Here's a pic of both sides, and the engine overall. I'm trying to hide as many wires, lines, etc. as possible! I'm crazy for detail.
And the beast it's going back into. It's been lightened, fiberglass bumpers, some other things, probably in the 2300 lb range. It flies!
help with headers and burning wires radcojoe Engine 2 07-20-2005 03:50 PM
Plug Wires, Cross arc-ing?? arch Engine 10 10-07-2004 10:00 AM
Points and plug wires question western star Engine 3 08-08-2004 10:01 PM
Red 7mm spark plug wires? 67cuda Hotrodders' Lounge 11 07-21-2004 11:30 AM
Plug wires ???? Robbie Engine 13 05-20-2004 11:57 AM
