running rich - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2011, 08:40 PM
badknuckles's Avatar
you talkin to me?
running rich
after swapping the cam my firebird runs rich, i have tried retarding the timing in which the car starts to stumble so i advance it again.
since it is tbi nothing to adjust there. soooooooo???? huh
Old 04-29-2011, 08:45 PM
Sound like you need some programming changes.
Old 04-29-2011, 08:48 PM
you talkin to me?
im hoping not, i had the cam custom made. they said the cam is as big as i can go with no additional changes.
450 461 lift
203 209 duration
Old 04-29-2011, 08:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Is the vacuum at idle close to what it was before the cam change? If anything it will need MORE initial timing, not less.
Old 04-29-2011, 09:00 PM
you talkin to me?
i will have to check the idle first thing in the morning for sure, good call
Old 04-29-2011, 09:13 PM
sqzbox's Avatar
My pipes are my music
What year firebird is it?
Old 04-29-2011, 09:38 PM
you talkin to me?
91 305 tbi
Old 04-29-2011, 09:41 PM
you talkin to me?
white smoke rich or lean?
Old 04-29-2011, 09:54 PM
sqzbox's Avatar
Originally Posted by badknuckles
91 305 tbi
I hope you know that if you have the ESC (electric spark control) system you need to disconnect the connector in the wire loom on the firewall before making any changes to the initial timing with a timing light. Instructions should be on a sticker on the underside of the hood or radiator support bracket. Failure to do that will have your initial timing 20-25* retarded even though it looks right on the balancer.
Old 04-29-2011, 11:37 PM
you talkin to me?
duh of course i knew that!
where is this connector?
Old 04-29-2011, 11:43 PM
you talkin to me?
so i uplug the esc, set the timing and then plug it back in?
won't the esc just reset the timing once i plug it back in?
Old 04-30-2011, 12:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Old 04-30-2011, 06:18 AM
sqzbox's Avatar
To question 1, yes
To question 2, yes, but it will be right.
Old 04-30-2011, 01:19 PM
you talkin to me?
i get the concept, unplug it so the computer doesn't reset the timing while i am adjusting it.
what i don't get is, if the computer adjust's the timing. when i plug it in won't it just go back to where it would have regardless?
does that make any sense?
Old 04-30-2011, 05:10 PM
sqzbox's Avatar
No. The computer will adjust the timing from the info it get's from the sensors.
Temp. O2, air flow, and a host of other info. The initial timing has to be set with the control un hooked so it's not trying to change anything while your setting it. Once you set the initial and plug the connector back in, the computer takes over adjusting the spark timing for optimum performance and emissions levels just as it adjusts the fuel ratio for best mileage.
When you set the initial with it un plugged, shut the engine off, plug it back together and start it. Re-check the timing now and see what happens. Do not un plug the connector and plug it back together with the engine running.
Q-jet running too rich bigdog7373 Engine 4 08-13-2010 05:19 PM
running too rich? runn141 Engine 4 08-13-2008 04:07 PM
Still running rich 77ChevyBigTen Engine 5 07-11-2006 04:21 PM
still running rich Blob Engine 0 06-22-2004 09:52 PM
Rich Running 400 Sbc Help !!!!!!!!!! Sampson Engine 4 07-01-2003 10:18 PM
