Running Rich after motor install (89 Lebaron...again) - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2005, 10:08 PM
New Member
Not a Hot Rod (Sisters car), but I figured there'd ba a few Mopar guys who can help me.
I just installed a 2.5 from a 93 Spirit into an 89 Lebaron. Starts up fine but is running amazingly rich. I don't know if it has one, but it's seems like it's in limp mode. It's got TBI and you can see it dumping in fuel at idle.
I cleaned the 2 electronic connections on the throttle body and rechecked the rest of the wiring harness. Looking at the setup, I don't see any proisions for measuring air, air temp or any other factor that would determine how much fuel should go in.
...So I have two questions: why is it dumping fuel, and how does it measure air
Old 05-23-2005, 10:19 PM
Siggy_Freud's Avatar
Probably uses a map sensor (Manifold Air Pressure). Look for a sensor connected to a vacuum line. Could be any number of reasons its running rich. You really need a scanner to properly diagnose the situation.
Does it seem to get better after its warmed up and has been running for a few minutes? Is the oxygen sensor connected? How new is it?
Bringing history and technology together.
Old 05-24-2005, 09:33 AM
New Member
The oxygen sensor is hooked up and the situation doesn't improve at all when it gets up to temp. I saw nothing on the intake manifold that appeared to be a map sensor.
Old 05-24-2005, 10:53 AM
sbchevfreak's Avatar
Licenced Automotive Technician
MAP sensor could be mounted on the front of the p/s strut tower. It's a small rectangular gizmo, 'bout 1"X2.5" with a three wire harness plugged into it, and a 7/32" vacuum line attatched.
Old 05-24-2005, 11:14 AM
New Member
So you're saying it's mounted remotley and fed a signal?
Old 05-24-2005, 12:36 PM
Yes, many of them are. All it needs are the power supply, and reference wires, as well as a vacuum signal to calculate air pressure.
Other systems use a Mass Airflow sensor in the intake track, while other systems utilize both.
Old 05-24-2005, 08:07 PM
curly5759's Avatar
Some Chryslers of that vintage mounted the map sensor piggy back on the computer, under the dash. The map needs a vacuum signal to calculate load. With no vacuum, it will think you are running wide open and add fuel to compensate. Usually they run very poor with map disconnected.
running rich and no advance 85mustang Engine 6 02-02-2006 10:57 PM
IS my Engine Running Rich? sum87mustang Engine 3 06-06-2004 09:38 PM
Mustang problem, running rich Speedwagon98 Engine 2 10-07-2003 09:54 PM
Need help -- SBC running rich all of a sudden jodz Engine 6 09-05-2003 09:59 AM
Rich Running 400 Sbc Help !!!!!!!!!! Sampson Engine 4 07-01-2003 10:18 PM
