Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Running rough under load mystery.
Old 09-20-2013, 04:44 PM
martyminnesma martyminnesma is offline
Originally Posted by 69 widetrack View Post
check your ground cable from the engine to the a heavy gauge wire from the block to any area of the truck that has a clean ground...see if the engine doesn't perk up. Often these problems can seem overwhelming when they are something very a ground wire...I know you mentioned it...Have you tried it?
tried a new heavy gauge ground wire, it did not make a difference.
