Running rough under load mystery. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-22-2013, 02:39 PM
All Figured Out!
so i finally figured this mess out. the main issue was a simple back spark plug wire, looks like it burnt out on the exhaust or something. but because the exhaust was wrapped it probably only shorted out some of the time.
when i replaced the spark plug wires (I bought some nice customizable MSD wires) I also bought a new MSD distributor. mine seemed to have a lot of play in it causing the timing to move around. also even with medium weight springs it never advanced more than 8 degrees when i should have been getting 20 degrees. the new distributor also seemed to make a big difference
I also changed the plugs, I'm sure a few of the old ones were fouled from running too rich.
thanks for all your help guys. good luck on your projects.
motor runs rough under light load Kilrcady Engine 14 07-12-2011 08:40 AM
2.8 v6 rough running dragonxdynasty Engine 3 07-03-2010 06:20 PM
1995 chevy S10 4.3 non-Vortec running bad under load? CamaroHunter78 Engine 2 05-12-2009 12:24 AM
running rough rodneydav123 Engine 2 12-18-2006 10:47 AM
Running Rough Guy Hiltz Engine 2 04-19-2006 05:29 AM
