running temp - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2004, 04:29 PM
astrops's Avatar
running temp
hey guys, question for ya,
72 chevelle 350 hi perf.
my running temp is at about 220, just put a new 160 thermostat in. is this too high, and what should i look for??
thanks again
Old 05-14-2004, 04:49 PM
camaroman7d's Avatar
Need more info., when does it get up to 220*? (idle, traffic, highway, etc..). I think 220* is too hot (especially for a N/A 350). What kind of fan are you using? I would also suggest a 180* thermostat.
If it heats up only at idle you need to move more air (make sure you have a shroud, etc..) or your timing could be retarded. If it heats up while on the highway you either have something blocking air flow (like a flex fan), or you need more cooling capacity (larger radiator) doubtful.
Provide more infoand I am sure it can be figured out.
What are you using for coolant?
Royce
Old 05-14-2004, 04:52 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
As posted in the other thread with the same question,
check your gage and sender unit first, they could be wrong.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 05-14-2004, 06:37 PM
Are you getting your temp reading from a good guage
And where are you taking your reading from?
I aggree with the 180 stat as well...loose that 160
Old 05-14-2004, 07:30 PM
troy-curt's Avatar
There is a lot of different sending units that will fit, But there is just one that will work right. It's got to match the gage and the engine. And they can go bad. I've had lots of early camaros and chevelles come into the shop with running hot problems, most were fixed with the proper sending units installed new.
Good Luck
Troy
Old 05-14-2004, 08:04 PM
Tim240Z's Avatar
Keep in mind that you want your oil temp up around 220-240*, at least for short periods to burn off impurities....
The electric fan in my 94 Z28 (PCM controlled) doesn't even turn on until 220*.
If 220* is the max it gets to, then i think you'll be fine...
