One thing I didnt do is actuate the throttle when the car is sitting still - parked and the air cleaner nut is loosened. if it's hitting the linkage that's when it would be noticeable. I'll try that. unfortuneately everytime I stroke the throttle it dumps fuel into the intake manifold form the shooters. |
check to see if the air filter lid is getting too close to the tops of the bowl vent tubes that stick straight up. If there is insufficient clearance, we used to cut the tubes to a 45* angle (High sides to the rear) to give them more air or drill a 3/16 hole on the front side near the top of the tube. What happens is that the air rushing past causes a vacuum around the tubes and sucks a vacuum on the float bowls..... ![]() Rather than modify the carb.....If it will fit, use a 4 inch tall air filter. |
Doc here,
I had one with a brand new Edelbrock Air-cleaner installed, and It did the exact same thing.. Turns out under inspection, the tube for the breather on the bottom of the Air cleaner, when tightened sat very nicely into the choke linkage and jammed it.. All needed to d to rectify the problem was turn it a 1/4 turn and bolt it back down.. You might want to look.. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
I have seen people over oil K&Ns and choke the engine.
Lee |
to any of you following this thread. I road tested again today with more interesting results. I disabled the secondaries and road tested with the air cleaner on. Ran like crap again at wide open throttle. removed the air cleaner and she ran great. so it's not a "secondaries" issue. It happens when running only on the primaries. for some reason when that air cleaner is installed she runs like crap at WOT. what the heck is going on?
Lee |
If it's a stock type filter try another brand. Instead of a K&N check out the AMSOIL foam filters. I like them better -- they seem to breathe at least as good as a K&N and you can't ruin them by getting the wrong oil on, they use motor oil. Easier to clean too -- no special kit or fluids to buy.
Sounds like you need to adjust the carb with the air filter on. It should be running a bit richer with the restriction of the air filter. I bet the carb was set up without a filter and that's exactly what's happening now -- it's way rich at WOT. A low restriction filter (like the AMSOIL or a K&N) might fix it right up. No, I'm not an AMSOIL dealer, but got a filter from a dealer friend to try and noticed the difference right away! That was after a K&N was ruined by spilling motor oil on it. You can't clean a K&N once it gets a petroleum based oil on it. It stops up at the area the dino oil contacted it just as if you stuck a piece of sheet metal over it. |
I'm still having problems with this. I will roadtest the car again this weekend. My next trick is to put the air cleaner on but cut away about half of the paper element and then run it again to see what happens. I don't know what else to do at this point.
Lee |
| Air Compressor Types- What do you have? | ChevelleSS_LS6 | Garage - Tools | 129 | 08-23-2009 09:11 AM |
| EFI air cleaner | fordpop | Engine | 0 | 12-04-2005 11:26 AM |
| FRAM air breathers!!!! | Robbie | Engine | 70 | 09-22-2005 05:52 PM |
| Air cleaner ??? | nitrofc | Engine | 1 | 03-06-2004 06:05 PM |
| air cleaner | gnarlydude | Engine | 11 | 10-03-2002 02:37 PM |
