Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Runs rough/intake popping when secondaries kick in.
Old 06-09-2013, 02:07 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Get the ignition timing sorted out starting here....
http://www.crankshaftcoalition.com/w...op_dead_center
Carter, Edelbrock and Rochester carbs will tolerate only 5 psi at the fuel inlet before the pressure unloads the needle and seat and allows the pump to blow raw fuel into the intake manifold. Holley carbs will generally tolerate up to 6 lbs before doing the same thing. Tap off at the carb inlet and monitor the fuel pressure with a 0-15 psi mechanical gauge. If fuel pressure is excessive, using a mechanical pump, replace the pump with a common, simple pump from Autozone. If using an electric pump, install a regulator and adjust fuel pressure. A regulator generally will not work on a mechanical pump due to the pulsing.
