Runs rough/intake popping when secondaries kick in. - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 06-20-2013, 09:21 PM
Well, it runs great. Go figure. 'Stomped' on it a ton of times, and she pulls clean until she can't pull anymore. Rev it in neutral, and it's clean too. Go figure. Still have the dripping problem from the primaries after shutting it off, but at least we can go wake surfing now.
  #32 (permalink)
Old 06-20-2013, 10:01 PM
Its possible you had an air leak at the fuel pump inlet line or any other section of the line you touched a connection on as I rather doubt a bad fuel pump would suddenly decide to work properly. Then again some foreign matter in the float bowl that had come dislodged with all the hauling back and forth you did ... hard to say.
  #33 (permalink)
Old 06-20-2013, 10:34 PM
if its popping through the intake upon hitting the secondaries that mens the secondary circuit is lean try lightening the secondary spring see if it gets worse or better may need also a bigger metering plate in the rear may possibly need a bigger carb. check with a timing light to see if distributor is advancing how much and may be to slow.
  #34 (permalink)
Old 06-21-2013, 08:34 AM
I think this has been a sequence of clearing up issues. From the replacement of the coil until possibly simply burning some 'bad' fuel, as well as maybe incidentally fixing an air leak, it all worked out.
Anyone have an idea about the fuel dribbling into the carb from the primary jets after I shut the engine off? It's enough to cause too much fuel to be in the engine for the next start up....so it takes awhile to crank that out and get a good mixture.
  #35 (permalink)
Old 06-21-2013, 09:21 AM
Not sure if the Holley has similar parts or comparable parts that a Quadrajet has, but I also experienced rough running/popping when the secondaries kicked in, but on a Q-Jet.
After many hours of diagnostics we took the carb apart, there is a cam which lifts the secondary rods up out of the seats, and this plastic cam was broken. A 5 second replacement and the problem was instantly fixed.
peace
Hog
  #36 (permalink)
Old 06-21-2013, 12:17 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I think I mentioned this earlier ..
Holley Heat Shield.
It keeps the heat away from the float bowls, and prevents the thermal expansion of the fuel in them.
  #37 (permalink)
Old 06-21-2013, 12:49 PM
66GMC, good thought. However, it'll do it even after I've only ran the engine for about 30 seconds, so I'm doubting the heat could build up that quick to make a difference. Am I wrong?
  #38 (permalink)
Old 06-21-2013, 01:31 PM
Hmmm, so only ran for half a minute from a stone cold engine and its dribbling like that. That makes me lean towards a thought of too high a float bowl fuel level and were these floats changed out with new ones or were they reused. Some floats are bad for fuel saturating in a few years time and they will sink deeper into the fuel as a result so even if the level was set mechanically ok, because the float is sinking its the end result that matters. Did you say that this carb doesn't have level check plugs on the side of the bowl ?.
  #39 (permalink)
Old 06-21-2013, 02:48 PM
Check out what Northern Chevy says.
Years ago I had problems with a car, removed and rebuilt the carb. Ran perfect for a short time and then the problem reappeared. I went through this 3 times. Finally, on rebuild kit number 4, I dropped the float (not included in the kit) into a cup of fuel. It sank to the bottom. I refer to this to this day as "the carburetor float that didn't".
Best of luck.
PatM
  #40 (permalink)
Old 06-21-2013, 03:52 PM
Awesome info. The floats were re-used. I'll probably pop the float bowls off next week and check. Thanks!!!
  #41 (permalink)
Old 06-24-2013, 08:21 AM
Engine ran great, but when I shut it down, I couldn't get it re-started. I have two new batteries on the boat, the electrical system is simple and visible, I checked voltage drops, and everything was great. I took the starter in to the local parts dealer. The first place was a flop....they had some lady working there that couldn't tell my why the armature tested bad...she said, 'I don't know, it's an electrical thing'.... The second place let me watch the test, and I could see the shaft bearing was completely shot. Replaced the starter ($52), tested the crap out of the engine, and it fires perfectly every time, hot or cold. Still going to check out that fuel dribbling issue, but also going to concentrate on getting this thing ready to sell. Time for another boat! The full repair to make this engine run fantastic is about $150 out of pocket. Whew, thankfully I didn't panic and buy a carb!
  #42 (permalink)
Old 06-25-2013, 10:24 AM
66GMC's Avatar
Yeah, 30 seconds run time wouldn't generate enough heat to do that, and I think those that suspect the floats are probably right.
I'm not sure if you've ever confirmed the List Number of your carb or not.
I had presumed List #80551 earlier, which would have used a nitophyl side-hung float ... Holley #216-43.
I don't see a brass float option listed for those internally adjusted needle & seats ... but you could call or e-mail Holley Tech and ask them.
suddenly runs really rough 23 tbucket Engine 16 07-21-2012 02:39 PM
350 ramjet runs rough adrepair Engine 2 11-21-2011 10:31 AM
need more low end, secondaries kick in hard, timing or jetting?? 350cruiser Engine 6 09-29-2011 09:05 PM
Engine runs rough. lt1bbody Engine 19 09-13-2005 01:27 PM
Runs Rough when Cold airman_turtle Engine 6 07-21-2005 01:25 PM
