Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 01-15-2007, 10:35 AM
ballard47 ballard47 is offline
Rust
Need a little help with some major rust removal. Is muratic acid that good at removing deep rust?
Old 01-15-2007, 10:38 AM
poncho62's Avatar
poncho62 poncho62 is offline
Moderator
 poncho62's barnstar
Wiki Edits: 4
re: Rust
Rust never sleeps......best way is to replace it with new metal....
Moving this to body forum.
Old 01-15-2007, 12:46 PM
39Hemi's Avatar
39Hemi 39Hemi is offline
re: Rust
Actually rust can sleep, just remove the source of oxygen...
To better answer your question I need more information, are we talking heavy surface rust but not much pitting, or is it suface but heavily pitted, or do you have areas were the rust has penetrated all the way through the metal. Depending on your particualr circumstance your treatment options will vary and it will also depend to a certain extent on what you want from the vehicle. To answer your general question there are much better products than muratic acid. Give me some more details and I'll describe some options.
Old 01-15-2007, 01:41 PM
oldred oldred is online now
re: Rust
This Muriatic acid (Hydrochloric acid) thing was discussed in detail sometime back and it really is not a good idea. The Muriatic acid will remove rust but it sets up the metal for further corrosion and the process is nearly impossible to stop, in short DON'T get Muriatic/Hydrochloric acid anywhere near your car! Once the metal is contaminated with that stuff you will have big problems even if not apparent at first. Phosphoric acid works quite well and can prevent further rusting but the Muriatic/Hydrochloric acid causes the wrong chemical reaction.
Old 01-15-2007, 01:48 PM
scrot's Avatar
scrot scrot is offline
re: Rust
Did someone say hydrochloric acid?
Old 01-15-2007, 03:45 PM
re: Rust
Muriatic acid and Hydrochloric acid are the same thing, Muriatic is just the old name for the stuff.
Old 01-15-2007, 04:24 PM
DougMN DougMN is offline
re: Rust
It is usually IMPOSSIBLE to remove all rust and replace it with metal.PURE FACT.
Old 01-15-2007, 05:05 PM
SHIFTY101EASY's Avatar
SHIFTY101EASY SHIFTY101EASY is offline
re: Rust
assuming we are talking about a certain area on the car...say a quarter sized rust hole or something average like that....how is it impossible to cut that piece of metal out and replace it with new metal and not have effectively gotten rid of the rust?
Old 01-15-2007, 05:38 PM
poncho62's Avatar
Moderator
 poncho62's barnstar
Wiki Edits: 4
re: Rust
What he is saying is, that there are areas of the car that you cant do that....and I agree. You can never get it all..........Unless you are on that Muscle car show, and they give you a brand new Camaro body.
Old 01-15-2007, 09:14 PM
re: Rust
One thing is for sure, putting hydrochloric acid on the rust is not the answer
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Rust"
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 135 02-18-2008 01:48 PM
big rust "problem" with former vinyl top car bullheimer Body - Exterior 3 02-14-2006 11:08 AM
phosphoric acid based rust dissolver rlackey Body - Exterior 15 01-05-2006 06:07 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 04:48 PM
RUST..What are the acceptable permanent ways to get rid of it? Rocket1 Body - Exterior 174 09-28-2005 06:37 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
