rust - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2005, 05:49 PM
rust
I am gonna be doing my truck in a week or tow, I noticed some rust bubbles starting to form, can anyone tell me the proper way to go about getting rid of these, they are not all the way through, after I sand them down should I epoxy prime them then fill then 2k high build prime?
Old 05-03-2005, 05:59 PM
Ratchet's Avatar
Last journal entry: Ontario Camaro Nationals 2008
Depends on how long you want it to last and how severe the rust really is. I have stopped taking chances with rust if I cannot completely remove the rust by either sanding of disc grinding I have taken the drastic measure of cutting it out and putting in a new piece of metal but that is just me. I see lots of posts on here where guys use naval jelly to remove surface rust and they all swear buy it but again I think it depends on how bad the rust really is. If after removing the rust with a grinder or naval jelly or whatever method you chose and you look really close and can still see these little tiny black dots in the steel that is rust and it goes deep. I would cut it out.
Just my opinion and I am not an expert by any strectch of the imagination.
Ric
RUST..What are the acceptable permanent ways to get rid of it? Rocket1 Body - Exterior 213 10-30-2011 06:23 AM
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 09:36 AM
phosphoric acid based rust dissolver rlackey Body - Exterior 15 01-05-2006 07:07 PM
Body work (RUST) Trav Body - Exterior 10 10-06-2003 11:27 AM
Phosphoric Acid + Prevention of flash/surface rust unstable Body - Exterior 3 07-21-2003 07:36 PM
