rust - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-01-2002, 08:39 PM
New Member
Post
about rust remover;some of the so called rust converters are basicly muratic acid. it is cheap and when cut with water, it can make a good converter. sheetmetal shops are a source where you can find it .
  #17 (permalink)
Old 02-05-2002, 06:38 AM
Post
YES, BY ALL MEANS RUST CONVERTERS DO WORK.
HOWEVER THERE IS A COMPANY CALLED "RESTO
MOTIVE LABORATORIES INC" WHICH MANUFACTURES A LINE OF PRODUCTS CALLED "POR-15". MAN, THE STUFFIS GOOD AND DOES EVERY THING THEY CLAIM. I HAVE USED THESE PRODUCTS IN MY OWN SHOP NOW FOR AT LEAST TEN YEARS AND TO THIS DAY THIS STUFF NEVER CEASES TO AMAZE ME.
THEY HAVE PRODUCTS FOR RUST REPAIR & PREVENTION(BELIEVE ME ONCE THIS IS APPLIED THE RUST AAAAIN'T COMING BACK), ENGINE PAINT AND EXHAUST PAINT THAT WON'T BURN OFF, GAS TANK SEALER,WOOD SEALER--THE LIST GOES ON. SOME PEOPLE CALL IT "POWDER COATING IN A CAN". ONE BIT OF WARNING, IT PERFECTLY SAFE TO USE BUT WEAR RUBBER GLOVES --IF
IT DRIEDS ON YOUR SKIN IT WON'T COME OFF FOR A COUPLE WEEKS---- "TRY IT YOU'LL LIKE IT"
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 09:36 AM
Rust Spots WildBill Body - Exterior 3 11-09-2007 06:22 AM
need help on wiki article: pitted rust Jon Body - Exterior 4 08-07-2007 09:38 AM
big rust "problem" with former vinyl top car bullheimer Body - Exterior 3 02-14-2006 12:08 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
