Rust around rocker holes - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2009, 09:39 PM
cab cab is offline
All,
I have finally restarted my paint and body phase for my 67 Firebird and the first step is stripping the multiple layers of paint. Anyway, the rocker panels below the driver door have little holes in them. These are not rust holes, but holes for the trim panels that screw on there (or weep holes not 100% positive). Anyway around these holes I have surface rust. I can remove teh surface rust easily enough, but of course my real concern is "what's on the inside" of that rocker. The metal isn't soft around the hole, but of course I'm envisioning rust sitting on the inside waiting to creap around the hole and back to the exterior paint surface after a repaint. Is my only option to cut out the entire rocker surfaceand weld in a patch the full lenht after treating the backside with weld-thru primer? I hate to have to go through all that effort given that 42 years later this metal still hasn't rusted through and doesn't appear anywhere near doing so.
Any advice is appreciated - as usual!
Thanks,
Chris
Old 05-25-2009, 08:14 AM
chevelle_man64's Avatar
I am the Chevelle Man!
Last journal entry: Grill Support
You could cut all that out like you said and repair it, but what if it doesn't need it? The hours and effort could be used on another part of the project. What I would do is take the nozzle and straw off of a WD-40 can, put it on a can of Permatex rust treatment, and shoot it full. It's alright if it leaks out of the hole, you'll sand it anyway. It goes without saying to be sure to get the dirt and anything else in their out first. Water hose, air hose, whatever it takes. Then go back and spray some black Rustoleum in there, and you shouldn't have any problems.
Or, if you are really worried, you can get a mechanics camera and look through the plug at the rear wheel housing.
-Brian
Rust in the trunk onebadmerc Body - Exterior 6 12-31-2008 10:32 AM
Good luck with Por-15 Crazy Fast on Ice Body - Exterior 36 11-05-2008 02:14 PM
What is the best way to clean rust off of an engine block coinbandit Engine 4 11-04-2008 04:44 PM
Rust question...again ScotY Body - Exterior 7 09-28-2008 09:16 AM
Filling up holes in body, including rust holes Mr.56Chevy Body - Exterior 5 12-12-2002 11:55 AM
