Rust bullet/what primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2006, 11:17 PM
Hi Guys,
I'm starting a project restoring a 67 C10. I have the cab off and stripped it down to bare metal and welded in some new sheet metal parts. I ended up spraying it with a product called Rust Bullet. I'm unclear on what product to use next before paint. Rust Bullet is similar to POR-15.
Any help would be greatly appreciated.
Thanks,
Hurdy
Old 11-22-2006, 08:47 PM
roger1's Avatar
Originally Posted by Hurdy
Hi Guys,
Thanks,
Hurdy
I think you are not getting much help here on this because pretty much everyone here would have told you to use epoxy primer instead of a POR-15 like product on the bare steel.
I have never heard of Rust Bullet. What does that company recommend to use over it?
Old 11-22-2006, 09:17 PM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
Hi Guys,
Thanks,
Hurdy
I haven't used the Rust Bullet product and their website is somewhat evasive on the answer just saying "work with any topcoat" - they don't say anything about scuffing or further prep work
Since they don't outright tell you I'd treat this stuff the same as any other base primer I might use...if its been over 24-48 hours your best bet is to lightly scuff with 180, do any major bodywork and and apply a couple of coats of high build primer like PPG k36. This will give you a base to start blocking.
Old 11-23-2006, 08:11 AM
BarryK's Avatar
I have no clue what this stuff is but someone mentioned about being like por15. Well there are chemical companies that will give you the formula to make a por like product or have it made for you and put your label on it.
The product is cheap to make and easy so I would guess there are a lot of copies out there.
With this in mind I would not do anything with anything over the product you are using until you talk with the company.
If it is a copy of por then you will need what they call tie coat before applying anything over that product so it does not peel down the road.
Your pretty deep into the job at this point to be short cutting or screwing up so I would call.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
rust under original primer coat? Dad&Son Body - Exterior 2 09-30-2004 06:56 PM
Primer that wont rust... fox Body - Exterior 16 11-12-2003 04:25 AM
rust under primer oldred Body - Exterior 5 08-27-2003 07:34 PM
