rust caused by cats urine - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2012, 07:12 AM
acman's Avatar
Last journal entry: Interior
Working on inner and outer fenders of my 55 chevy truck. had both ready to prime. was trying to get more ready when a cat sprayed spots of both fenders. sand blasted spots yesterday but did not prime. this morning went out to find the exact out line of the spots. not rusty but visible. do you know of anything that will neutralize cat urine?
Old 11-24-2012, 07:23 AM
gearheadslife's Avatar
MentalMuffinMan
baking soda
Old 11-24-2012, 07:24 AM
Try steel wool, with a phosphoric acid solution. One of the wide men on this board recommends using Ospho to treat bare metal.
Old 11-24-2012, 08:37 AM
At least 1% baking soda in a water solution. Since you sand blasted, I would use a SS wire brush to scrub it good with the solution and rinse well. But that really needs to be done right after the fact, I'm not sure about urine acid, but the fumes of some acids will rust adjacent areas so watch for that.
Old 11-24-2012, 09:02 AM
Last journal entry: 27
i can think of a few things that will neutralize that cat...
Old 11-24-2012, 09:16 AM
acman's Avatar
still love my wife cats and all. thanks
Old 11-24-2012, 11:16 AM
da34guy's Avatar
Yep, a shotgun works real good.
Old 11-24-2012, 11:42 AM
Cat urine
I agree with the Shotgun. I had a similar mishap a while back when a cat urineated on a pressure plate (clutch). Just about impossible to fix. Good luck whatever you try.
Old 11-24-2012, 01:40 PM
malc's Avatar
Born To Be Mild
Old 11-25-2012, 05:14 PM
302 Z28's Avatar
Shotgun is way too expensive I have found my RWS .177 pellet rifle (1100fps)to be deadly. and very quite.
Vince
Old 11-25-2012, 05:18 PM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
get a bull dog.
Old 11-25-2012, 07:15 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Cats... Go figure?? Have you ever seen a thread about "post a picture of your cat in your Hot Rod? Yeah, there's a reason for that.
Once the cat uses up its nine lives get a dog.
Problem solved.
Old 11-26-2012, 06:39 AM
deadbodyman's Avatar
Wiki Edits: 11
Naaaa....Too much noise...Try running an extention cord out to the truckand electrifing it....
Old 11-26-2012, 07:24 AM
220 VOLTS of course!!.
Old 11-26-2012, 08:00 AM
That is a nice gun, if your ever in R.I. maybe we can go shoot a few rounds at my gun club. Lot cheaper to shoot than a 22 or a centerfire.
please help cats or no cats 1996 4.6liter 1996thunderchicken Engine 12 06-27-2011 12:34 PM
D-rust it, Safest rust remover, Evapo rust. 35prog Body - Exterior 21 05-02-2009 02:56 PM
OLd cats LarryMcCoy Body - Exterior 0 04-04-2008 05:54 PM
OLd cats LarryMcCoy Body - Exterior 0 03-29-2008 03:00 PM
Urine Test! dawg Off-Topic 20 01-06-2008 02:34 PM
