Rust Dimples??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2003, 06:29 PM
New Member
Post Rust Dimples???
I am going to remove my front clip and have the frame sand blasted and wire wheeled. But I notice alot of dimples in the frame that wont be filled in with the paint. I am planning on just painting with some chassis semi gloss black but want a smoot finish it is on a 72 nova
Old 01-20-2003, 07:05 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
you can either use a light coat of plastic filler or I recomend using the silver high build POR-15. your front clip will not only be completely rust proofed, but the silver POR-15 contains a filler to fill any small imperfections. After the silver you can use their Chassis Cote topcoat.
HK
