Rust Dissolver versus Rust Convertor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2005, 06:12 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hi folks,
I read thru most of Randy Ferguson's excellent post on how to use Naval Jelly which is used to dissolve (surface?) rust.
The implication in that thread seemed to be that rust "convertors" didn't work very well?
It seems to me that they are intended for 2 different (but similar) purposes. I see naval jelly being used on accessible areas to remove surface and "flash" rust, while rust treatment would be used in all of the "nooks and crannies" to seal and protect? This might also be good for pitted areas?
My impression of the naval jelly is that you have to make REAL sure that you rinse it off very well, or any moisture later would re-activate the acid?
I have never used either of these products yet, but plan to do so quite soon. Can anyone confirm or deny my beliefs? I'd really like to do this right...
I did a little bit of my own research on these items at Permatex's website as well as pulling a couple of bottles of of the shelf at our NAPA store. Here is what I have found:
NAVAL Jelly
http://www.permatex.com/products/pro...&item_no=81756
Permatex Canada uses NJ-1C (UPC 80594) as a part number for the 236 ml size and calls it "Rust Dissolver Gel".
"Contains Phosphoric Acid ..."
"Rust Dissolver Gel removes rust by powerful chemical action. Applies easily with a brush. Rinse rust away in just minutes. Adheres to vertical surfaces. Provides 24 hour flash-rust protection for priming, painting or other finishing."
Rust Treatment (I believe this to be the same as "Rust Mort" that several others have mentioned.)
http://www.permatex.com/products/pro...&item_no=81775
Permatex Canada uses 81387 as a part number for the 946 ml (1 US QT) size and calls it "Rust Treatment" - "Destroys Rust!".
"Contains Vinylidene Acrylic Copolymer ... Barium Sulfate ... and a whole lot of other nasty-sounding stuff ... cancer-causing, birth defects, reproductive harm..."
(Quotes)
- Destroys old rust and prevents new rust.
- Can be used with body fillers and fibreglass
- Dries to a tough protective primer coating
- Seals and protects metal.
There is a lot of good information in the directions as well, but I don't have the time to type it all out right now.
Highlights (paraphrased in my own words):
Scrape or wipe dirt and oils.
Sand or wire brush rust.
Pour into seperate container, do NOT contaminate the unused portion - chemical reaction.
Brush or sponge a thin layer. Apply carefully, product will stain surrounding paint. Remove splatters with water and detergent immediately.
A black coating will appear in 15-30 mins, apply a second coat within 20 mins.
Allow 24 hrs protected from moisture before topcoating.
Acrylic Latex paint requires a primer/sealer before painting.
Laquer/Enamel may be painted without a primer.
AUTOMOTIVE APPLICATIONS: Allow an extra 24 hrs drying time before topcoating. Use sandable primer and 120 grit paper before topcoating.
Thanks for taking the time to read all of this, and all replies, comments, and advice will be greatly appreciated!
Thx,
Don
Old 07-08-2005, 06:51 AM
AhX AhX is offline
New Member
while I am not the best body man in the world, I have used the converters and have had no luck whatsoever withthem. My 88 blazer is rusting through already where I used it. Next time I will be using the naval jelly to verify that all the rust is GONE not "converted"
Old 07-08-2005, 09:45 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Rust NEVER sleep's. You may put it to bed but it will eventually wake up.
Old 07-09-2005, 03:26 PM
Last journal entry: 99 soft tail standard I painted
Im with you Bee4me
Old 11-05-2005, 08:49 AM
rbfpezcore's Avatar
Not fast, but loud as hell
So is Naval Jelly just another temporary solution then? The only way to really RID the car of rust would be cutting and welding?
Old 11-05-2005, 09:57 AM
"Destroys rust and PREVENTS new rust"- MUST be true if it says so on the label
Old 11-05-2005, 06:26 PM
mitmaks's Avatar
Last journal entry: Grille
only thing that works is por15
Old 11-06-2005, 01:47 PM
Custom builder and painter
Last journal entry: Another test fit of the axle
BAH!!!! i've had rust come through Por15 so i'm not a true believer.. although I do think it's probably the best one out right now.... but the way i see it is have that stuff blasted if you want to stop the rust, or cut and well that's all folks
Old 11-06-2005, 05:41 PM
mitmaks's Avatar
been 2 years since ive coated trunk pan in my charger, oh ya...car sits ouside through rain/snow and water gets in trunk due to bad weatherproofing. No rust yet
Old 11-06-2005, 05:48 PM
I've only seen it come back one time.. So I don't get it but it makes me a little leary... like they say rust never sleeps
Phosphoric Acid + Prevention of flash/surface rust unstable Body - Exterior 13 11-15-2015 07:09 AM
RUST..What are the acceptable permanent ways to get rid of it? Rocket1 Body - Exterior 213 10-30-2011 06:23 AM
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 09:36 AM
phosphoric acid based rust dissolver rlackey Body - Exterior 15 01-05-2006 07:07 PM
underbody..rust convertor help please... Rubberman2003 Body - Exterior 1 06-26-2003 02:08 PM
