Hotrodders Bulletin Board > Tech Help> Body - Exterior
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 05-13-2006, 04:50 PM
workingclass's Avatar
workingclass workingclass is offline
Tool & Die Repair God!!!
Rust encapsulator???
Hey rodders, its been a while since I posted so here goes another question. Is there a plus side to using a rust encapsulator such as naval jelly and if so why wash it off with water after it turns black, doesn't that defeat the purpose???
Kevin
  #2
Old 05-13-2006, 07:44 PM
oldred oldred is offline
Naval jelly is a phosphoric acid based rust remover and not an "encapsulator" like POR 15 or Eastwood's Encapsulator crap. Naval jelly when properly used will remove rust while the so called encapsulators just cover it up and claim to stop it but it is still there.
Old 05-13-2006, 07:46 PM
shine's Avatar
shine shine is online now
Last journal entry: some progress
there aint no insulators in that can. remove it, never cover it up.
Old 05-13-2006, 10:18 PM
Brian_B's Avatar
Brian_B Brian_B is offline
Lost in the 50s!
Last journal entry: time to start body work
When used properly, naval jelly does a pretty good job of removing rust on chrome wheels. I don't know about other stuff. I think it will ruin paint though.
As far as eastwoods rust encapsulator.....I don't know if it works or not. The P.O. cleaned my frame really well and coated it with that. Again...I don't know how long ago, but so far no rust has come back.
I would assume he sand blasted the frame from looking at it (just a guess). I know he sand blasted some of the other parts before he painted them.
Old 05-14-2006, 01:30 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Those rust encapsulators and such..If one reads the instructions it will tell one to remove any residue before painting..the rust hardeners and such use a carrier fluid and that needs to be removed as it will interfere with paint adhesion..
This applies to any of the naval jelly..rust mort..picklex or any of those products of that nature..So apply it let it work and then wash off the residue and sand it out before applying any paint..That is if you use it at all..
Sam
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Rust encapsulator???"
ThreadThread StarterForumRepliesLast Post
big rust "problem" with former vinyl top carbullheimerBody - Exterior302-14-2006 01:08 PM
Rust Dissolver versus Rust Convertor?66GMCBody - Exterior911-06-2005 06:48 PM
rust encapsulator helpoldredBody - Exterior310-28-2004 08:31 PM
Por-15, ZeroRust, Rust Encapsulator, or Urethane?starquestBody - Exterior404-23-2004 09:36 PM
hamerite rust encapsulatorderwood3Body - Exterior001-16-2004 08:30 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
