RUST?! fresh from the oven.
OK, I built a sandblast cabinet, bought a powder coat gun, and found a working oven in the trash behind Lowe's (the installers leave the old ones out there).
I thought I would start with a rim. I blasted it with Black Diamond and it left black dust all over it. So i blew it off and then washed it down with plain water. I then put it in the oven (400 deg) to bake off the water. After about 20-30 mins I took it out and it was covered with surface rust. Is this normal? How do I clean it for powder coat? I'm afraid that the black dust with contaminate it. |
Water and fresh blasted metal don't mix. You should just blow it off with air & a brush. I don't think there is a way to get rid of that rust haze now without reblasting. Even if you got a derusting chemical, when you rinse it off with water it will rust again, even if you quickly blow dry it.
Is that stuff "black beauty" , the slag material? I've never had that stick to a part before. |
Yeah it's coal slag I think. It made a bunch of dust. It was hard to see even with the vacuum running. I'll just blow it off best I can.
I have found slag that has been magnetized. I'm not sure if you are having that problem though.
Magnetized?
I believe your referring to static cling from the blasting process. You don't wash the metal off with water.Really wish that was possible.LOL After blowing off what you can,use a grease & wax remover and wipe it down changing white rags till it wipes "clean". If it's just a light coating of surface rust,Use a red scuff pad and remove the residue then use the g&wr to clean it with. |
I wanted to use glass beads in the blaster but at $38 for 50#s it's a bit expensive. Black Diamond is less than $7. Nobody has that StarBlast stuff around here.
I'm not having problems with magnetization. I blew the rim off and wiped it down with denatured alcohol. The powder coat process wasn't as easy as I had hoped. It took me a while to get the gun lined out and even then it didn't flow to the part as well as expected. The finished product is pretty ugly. However, I did expect that result my first time and I learned a lot in the process. Thanks for all the feedback. You guys rock!
| RUST..What are the acceptable permanent ways to get rid of it? | Rocket1 | Body - Exterior | 213 | 10-30-2011 06:23 AM |
| secrets of surface rust removal revealed | Randy Ferguson | Body - Exterior | 178 | 09-24-2011 09:36 AM |
| big rust "problem" with former vinyl top car | bullheimer | Body - Exterior | 3 | 02-14-2006 12:08 PM |
| Rust Dissolver versus Rust Convertor? | 66GMC | Body - Exterior | 9 | 11-06-2005 05:48 PM |
| 04 mustang rust | oldred | Body - Exterior | 3 | 07-19-2005 07:15 AM |
