Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - RUST?! fresh from the oven.
Old 06-02-2007, 05:00 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Water and fresh blasted metal don't mix. You should just blow it off with air & a brush. I don't think there is a way to get rid of that rust haze now without reblasting. Even if you got a derusting chemical, when you rinse it off with water it will rust again, even if you quickly blow dry it.
Is that stuff "black beauty" , the slag material? I've never had that stick to a part before.
