rust inhibitor experience - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-05-2011, 01:01 AM
I've never understood why more people don't use zinc phosphate when it has numerous benefits over phosphoric acid.
For one, it removes rust better than acid treatments, it doesn't have to be neutralized, it leaves a nice gray zinc coating on bare metal surfaces giving protection against corrosion AFTER application (phosphoric acid gives no protection after application), application is far less messy (it's sprayed on),and is compatible with virtually all paint systems (phosphoric acid is not, ie SPI does not recommend their Epoxy over acid-treated surfaces).
I treat all my panels with zinc phosphate once I've got them to bare metal to protect against flash rust as well as remove any corrosion I couldn't remove mechanically. It also leaves the panel looking brand new.
There may be some other products out there, but I use a particular one, made right here in good ol Iowa called Phix by a company called PPC
http://ppcbest.com/catalog/product_i...products_id=43
  #17 (permalink)
Old 03-05-2011, 05:24 AM
deadbodyman's Avatar
Wiki Edits: 11
lizer,your zink phosphate sounds promising I'll pick some up and try it and compare it to Ospho but you have a few misconceptions about "ospho" ..Yes it's active ingrediant IS phosphric acid but it does not need to be neautralized just like an etching primers main ingrediant is Phosphric acid ,you dont neautralize that ...it does offer protection against surface rust....and although SPI does noy recomend using ANY treatments thier epoxy primer works very well with it ...I know first hand because I've been using ospho for for around 25 yrs and SPI has been my primer of choice for quite a few years also..At my shop,if I strip it or its blasted its gets the combo,
This is the first I've heard of the zinc so I'll try it on something and do a couple tests but the reason I still use ospho is because it works SO well and when something works well you stick with it...untill something comes along thats better...This zinc may be it ....we'll see
  #18 (permalink)
Old 03-05-2011, 10:47 AM
Is Ospho the same stuff as naval jelly or is there something more special about it? I have naval jelly I use too but this is in contrast to everything I've ever read about it, namely offering protection against surface rust. Even the label on my naval jelly states that I need to cover bare surfaces immediately or rusting will occur. Zinc is an ingredient alongside phosphoric acid in etching primers too The phosphoric acid etches the surface of the metal on a molecular level, which forces the zinc into the metal. This is essentially what confers any hint of corrosive protection the primer may have.
I'm a research scientist by day and through my job have access to the thousands of scientific journals available. When I choose my metal preps I study the chemical interactions that take place, and the peer-reviewed scientific literature has a plethora on this. There's a good abstract on zinc here and it's a short paragraph:
http://www.sciencedirect.com/science...7&searchtype=a
I know it's a little nerdy than what most people might care for, but a scientist and an old body guy could be a slam dunk dangerous combination!
With all that being said, I don't want to talk zinc phosphate up like it's a miracle product, because it's not. I'm often hasty in applying it if I just want to keep the panel as bare metal for awhile, and flash rust WILL come back if I don't do it well. If I do a poor job sometimes the panel will flash before my eyes at the end when I'm wiping the excess off with a damp rag.
I originally learned about it from an oooold body guy who professionally restores Mustangs (the first time I ever met him, he rolled out from underneath a Mustang he was prepping at the ripe age of 77)
  #19 (permalink)
Old 03-05-2011, 04:34 PM
Wiki Edits: 11
From what I understand about navel jelly they are close relatives but ospho is a lot more concentrated.I apply it with a pump spray bottle and right away it starts dissolving rust you can see it happening...
For light rust I apply it with the pump bottle and scrub it in with a scuff pad,for heavier and pitted rust I'll use wire wheels to work it into the pits.keeping everything wet as I'm working ,then just wipe off the excess with dry paper shop towels (lots of them) let it dry over night and if its in the shop you wont see surface rust again for months. the coating is a primer and paintable if your doing a trailer or something but I always sand it and epoxy prime it on my cars..I've never come across any primer that didnt stick well to it. Although others have I blame it on poor prep,it doesnt look like anything is on there.after sanding and scuffing wipe it down with wax & grease remover and start shooting your primer....The important thing about it is that even on media blasted cars it'll prevent surface rust on bare metal until your ready to prime and if it already has started to get surface rust it'll remove it quickly...I can apply a coat in less than an hour as a protectent .but it might take days if the car is heavily pitted...applying a second coat after the first has dried ,cleans it up even better...
How do you use the zinc phosphate????
  #20 (permalink)
Old 03-06-2011, 06:57 PM
The stuff I use (PPC Phix corrosion treatment) comes in a spray bottle and I degrease the surface first and then spray it down. Let sit for 5-15 min (longer if there's more rust) keeping it wet. Then I take a red scotchbrite and scrub the surface and wipe it down with a damp cloth. Do this once more if a lot of rust and corrosion remains. When it's at a point I'm satisfied with, or if I just want to spray it on a panel to protect it, you then spray a light mist over the entire panel, let sit for a minute, then wipe down with a damp cloth. This final step is what leaves the zinc coating on the panel.
I'd then put SPI Epoxy on the panel. To prep the panel I'll scuff the zinc'd surface with a red scotch brite then degrease.
Link to Rust Wiki Dealing with Rust OneMoreTime Body - Exterior 22 12-02-2011 01:30 PM
D-rust it, Safest rust remover, Evapo rust. 35prog Body - Exterior 21 05-02-2009 03:56 PM
Rear window frame rust, windsheild rust cpratt Body - Exterior 5 09-18-2008 03:41 PM
65 f100 and the battle of rust. z chrome rust defender? 65fordguy Body - Exterior 3 08-03-2008 05:16 PM
Best Rust Inhibitor? bigbrowndog Body - Exterior 45 11-21-2004 09:26 PM
