Rust Inhibitors - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2014, 02:15 PM
Rust Inhibitors
I have been doing a lot of reading up on rust inhibitors but have not found anything specifically addressing rust in inaccessable voids. The car I'm restoring (Porsche 914) has many strutural sections made up of multi layered sheet metal spot welded together. I have found rust starting to form between the layers of spot welded sheet metal and inside the spot welded seam.
I would like to address this condition by forcing a rust inhibitor between the spot welded layers of sheet metal but I'm concerned that acids in these products if not neutralized will introduce a new problem, acid erossion of sheet metal.
Are there products designed to be injected into tight spaces, stop rust and protect long term without needing to be neutralized?
Thanks for your input
Old 07-10-2014, 04:08 PM
maybe some photos may prompt a response
ID:	160257   Click image for larger version
ID:	160265   Click image for larger version
Old 07-10-2014, 05:41 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Corroseal Rust Converter | Application Guide | How to apply Corroseal
Sometimes you just gotta do what you gotta do.. I use this for those hard to get to places.. I use a sprayer with a long wand on it to reach up into those areas and just let the excess drain out.. About the best I know of to do with things like door posts and rockers..
Sam
Old 07-10-2014, 08:54 PM
Pats55's Avatar
The only way to cure this problem is to separate the two pieces of metal. There is nothing that will penetrate between two spot welded pieces of steel. Once you've separated the metal or cut it out, and acidic rust remover will clean it up. You could use calcium sulfonate paste in these seams before closing them back up.Phosphoric acid solutions will not eat up the metal You could use zinc weld thru Primer You can also use a rust encapsulator Primer.
Old 07-11-2014, 07:06 AM
deadbodyman's Avatar
Wiki Edits: 11
sand blast ,ospho,epoxy prime and seam seal ,then undercoat...
Old 07-24-2014, 01:08 AM
I've wondered for years about treating between layers of metal and areas that aren't thought of. Where the roof skin meets the structure, between outer wheelhouses and quarterpanels, inside unibody "framerails".... anywhere that's not usually considered when doing bodywork/paint.
Link to Rust Wiki Dealing with Rust OneMoreTime Body - Exterior 22 12-02-2011 01:30 PM
D-rust it, Safest rust remover, Evapo rust. 35prog Body - Exterior 21 05-02-2009 03:56 PM
Rear window frame rust, windsheild rust cpratt Body - Exterior 5 09-18-2008 03:41 PM
65 f100 and the battle of rust. z chrome rust defender? 65fordguy Body - Exterior 3 08-03-2008 05:16 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 06:48 PM
