rust-oleum overspray
I got a problem. Couple years ago I bought a little convertable that had at the time fresh black paint. The body and paint were not perfect, but I didn't pay a "perfect" price either. This year I had to paint a few items with white rust-oleum. ( not car stuff) So I went outside, on the side of the garage and sprayed my stuff. Couple days later I go to wash the convert. and I find that somehow I got a fine mist over the car.(Harley also). I tried cleaner wax, and real fine rubbing compound, but it didn't cut the overspray. What do I do now? I have no idea if the paint is bc/cc or single stage. I suspect it is single stage because of the quality of the body work, but that is just a UNEDUCATED opinion. Repaint at this point is not a option. Anybody got some ideas?
Norm |
You might try something like "Goof-off" on a small area and see if it works Goof Off Cleaner OR some Heavy Duty rubbing compound. It's more aggressive so you'd need to polish it out again but should cut into the overspray better. |
Those blue clay bars and some water will take it off. What are those clay bars called? Dangit!
Thanks guys, those all sound like some good ideas. I"ll give them a try in a day or two. Should have some time the Friday after Thanksgiving. By the way, I hope you all have a good Thanksgiving with your families.
Norm |
Yup yup....
If it was mine I'd just wetsand the overspray off with 2K grit finishing paper, and plenty of slightly soapy water to keep the paper clean. I'd use a small foam block so as not to sand ridges down into the paint, and sand with light pressure just until the overspray was gone, Then I'd cut and buff it all back out for a better shine than before the "Oopsie"...
Doc |
NORM: You might try giving RUSTOLEUM a call. They have a Tech Line and I have talked to them before. Their formula is quite simple most of their hipe is marketing. Let us know how it turns out... You never know what five grandsons might DO in out garage.... THANKS.... THERESA
I have sprayed a GREAT many gallons of Rustolum(machinery repair/rebuilding) and I have had to deal with overspray on everything from cars to house siding. I don't even consider the stuff paint as it is an industrial "coating" and even the term "industrial" is used loosely IMO. This stuff is junk and no exotic measures are called for to remove overspray, certainly not sanding it off
I still haven't had time to "play" with the paint yet. Should have time on Friday. I'll try mineral spirits first since I have that in stock. I'll try it on the lower pan first to make sure it does the paint no harm. I just wanted to write a quick note so you guys don't think I'm ignoring you. Thanks again. I'll let you all know what happens.
Norm |
| RUST..What are the acceptable permanent ways to get rid of it? | Rocket1 | Body - Exterior | 213 | 10-30-2011 06:23 AM |
| secrets of surface rust removal revealed | Randy Ferguson | Body - Exterior | 178 | 09-24-2011 09:36 AM |
| big rust "problem" with former vinyl top car | bullheimer | Body - Exterior | 3 | 02-14-2006 12:08 PM |
| Rust Dissolver versus Rust Convertor? | 66GMC | Body - Exterior | 9 | 11-06-2005 05:48 PM |
| 04 mustang rust | oldred | Body - Exterior | 3 | 07-19-2005 07:15 AM |
