Rust & painting
I have some cast iron parts that I have sand blasted and there appears to be some rust still down in the pores that I cannot get out. If I let them set for a day or two, the rust kind of grows a little and the spots get bigger. There is no scale, just dark surface rust, but down in the texture of the casting. Can I treat the surface with phosphoric acid to neutralize the rust, then prime with epoxy primer and finally paint the color I want? Will this work to give me a durable finish?
Try some naval jelly, let it set for awhile then scrub with a scotchbrite pad and repeat, it may take awhile but they should dislodge. Rinse with water when done and dry, then scuff and prime. Although it is recomended, I don't like priming over the phosphoric coating, I always sand or scuff it off before priming- reminds me too much of metal conditioner- at times I had some major problems with that stuff years ago.
| RUST..What are the acceptable permanent ways to get rid of it? | Rocket1 | Body - Exterior | 213 | 10-30-2011 06:23 AM |
| secrets of surface rust removal revealed | Randy Ferguson | Body - Exterior | 178 | 09-24-2011 09:36 AM |
| phosphoric acid based rust dissolver | rlackey | Body - Exterior | 15 | 01-05-2006 07:07 PM |
| Body work (RUST) | Trav | Body - Exterior | 10 | 10-06-2003 11:27 AM |
| Phosphoric Acid + Prevention of flash/surface rust | unstable | Body - Exterior | 3 | 07-21-2003 07:36 PM |
