Rust Pits - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2001, 06:34 PM
New Member
Unhappy Rust Pits
I have a 26t model with surface rust and some pitting. I have used a cupped wire brush and fiber backed discs on a angled grinder to remove the rust.Can anyone tell me what to use to treat the rust pits before bondoing and primer?
Old 11-27-2001, 06:50 PM
Tom Tom is offline
Post
the best way is to use a small sandblaster like a gilmore or sandy-jet they don't warp the metal blast the area untill it is flat grey in color this removes all the rust, if you leave any rust at all it will return with a vengence then treat the area with a metal prep, an acid based solvent that etches the metal wash thoroughly,dry, sand and prime then use a polyester type putty to fill the pits, smooth then prime again. Now there are products out there that convert rust into something else like "rust mort" or " sem rust seal" they will do the job but I don't know if they are permanent
Old 11-28-2001, 05:53 AM
New Member
Post
Great info Can you tell me where I can find either the gilmore or the sandy-jet blasters?
Old 12-01-2001, 07:18 PM
Tom Tom is offline
Post
I deal with Sherwin Williams they can supply a sandy jet or e mail me I can get one for you they run about 50 for the sandy jet but any auto paint store should be able to get one for you
Rust Pits in Rally Rims KenCam General Rodding Tech 6 06-18-2007 08:56 PM
Deep rust pits . BIG DOG Body - Exterior 4 07-17-2006 07:11 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
what do to with these rust pits? PICTURES inside montea Body - Exterior 5 05-05-2005 06:05 PM
What do I use to remove rust from pits in metal? Fordy8man Body - Exterior 14 02-14-2004 07:30 PM
