Rust Pits in Rally Rims - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2007, 07:32 PM
KenCam's Avatar
Grease Monkey Wanabe
Last journal entry: ALL IS LOST!
I'm in the process of sandblasting and powder coating my rallies. Some of the rims have deep pits around the inside lip. The pits are higher up on the lip and I don't think i'll have a problem with air escaping but I'm no expert. I'm sure others here have seen the type of rust pits I'm talking about.
Should I do something about it?
If so any ideas on how it fix them?
Thanks
Old 06-15-2007, 09:27 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Pictures???
Most of the sealing it happening in the bead radius of the wheel.
That 90* bend is where the dirt or a piece of torn rubber will let it leak .
The rubber will form to small imperfections & there is always bead sealer messy but effective.
Sometimes you can take a hammer & beat on the TIRE & it will seat up & stop the leak.
If they are really deep then maybe some epoxy or welding?
R
"SlowRide66"
"Illegitimis non carborundum"
Old 06-18-2007, 07:41 AM
KenCam's Avatar
Thanks for the reply.
I thought it would probably be OK but wasn't sure. I'm a bit of a perfectionist and things like that bug me.
Do you think that metal to metal stuff might work? I think I can powder coat over the top of it. If not I may have to wait to fix them. (my wife spent my wielder money )
Old 06-18-2007, 08:07 AM
Rob Keller's Avatar
Wiki Edits: 38
I am not sure what you mean by saying "metal to metal" stuff.
Take a few pixs & post them here.
If you don't know how lemme know & I will learn ya how to postApix
R
"SlowRide66"
Old 06-18-2007, 08:14 AM
KenCam's Avatar
Columbia Coatings has some called Lab-Metal. It is a filler with metal in it. I'll try to remember to take a couple of pics tonight and post them.
Old 06-18-2007, 05:27 PM
red_rider52's Avatar
DriveItLikeItsSupostToBeD riven
My father used Lab-metal on a rusted diesel fuel tank on his 18 wheeler that was leaking 3 or 4 years ago and its still holding today. He did lay it on thick tho. I not sure if its hard to sand down to get nice and smooth for you wheels, or how it would hold on small pits? Defiantly worked good for his application.
Old 06-18-2007, 08:56 PM
Rob Keller's Avatar
Wiki Edits: 38
WOW!! those are some SUPER KOOL products
I had no clue.
Of course what I don't know could fill up a entire INTERNET
You wouldn't want to use the "krinkle stuff"
LOL that would be like adding pits.
Thanks for the link.
R
"SlowRide66"
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
what do to with these rust pits? PICTURES inside montea Body - Exterior 5 05-05-2005 06:05 PM
What do I use to remove rust from pits in metal? Fordy8man Body - Exterior 14 02-14-2004 07:30 PM
Rust Pits 50Windsor Body - Exterior 7 07-18-2003 07:32 AM
Rust Pits James Groves Body - Exterior 3 12-01-2001 07:18 PM
