Rust Pitting - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2006, 02:27 PM
KeithP's Avatar
Rust Pitting, Help!
I'm sanding surface rust off with a DA and theres still some
light pitting. I found plain old white vinegar cleans them out
really good. Is this a no no?
Old 02-22-2006, 07:23 PM
No its not.
It must be very minor flash rust for the vinegar to work.
Vinegar also works very good on aluminum as an etch/cleaner.
However the vinegar must be washed off with water, so plan on coating when washed and blow-dried.
Old 02-22-2006, 07:59 PM
KeithP's Avatar
Thank's Mr.K
I have a 67 Cougar I started on, and it was primed with laq.
primer years ago. How many, I don't know. Started sanding
the top and it came off pretty easy. Got lots of little pits in
the top, so far I expect the rest of the car to be the same.
I work at home and I was gonna go get some pool acid to
etch it. I had a gallon of white vinager under the sink. I tried
it out and it seemed to work pretty darn good. I know this
might sound unprofessional, but that's ok. Any advice will be
listened to, and welcomed. Thank's KeithP
RUST..What are the acceptable permanent ways to get rid of it? Rocket1 Body - Exterior 213 10-30-2011 06:23 AM
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 09:36 AM
big rust "problem" with former vinyl top car bullheimer Body - Exterior 3 02-14-2006 12:08 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
rust pitting! mike bryan Body - Exterior 5 03-28-2003 05:19 AM
