Rust Proofing Gas tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2010, 08:43 AM
What is the best way to rust proof a steel tank? It is going on a 78 F-150 and I plan on driving the truck in WI winters some. I picked up a used tank in really good shape and don't want it to rust out right away. It is red currently, do I take the tank down to bare metal? What should I put on it?
Old 04-14-2010, 09:20 AM
Last journal entry: 50 Ply wagon
Spraying it with a good primer like an epoxy based will stop rust. But if you don't have a spray gun , you can use a good spray can primer and then coat it with a couple coats of undercoat. The undercoat will make a surface that will help repel stuff being kicked up on the tank and nicking it, then you would have bare metal that would start rust. Most good parts houses have spray undercoat the work well and actually will stay pliable even in cold weather.
Old 04-14-2010, 09:53 AM
So it sounds like the best option is to do epoxy primer, then paint it and then put undercoat on the bottom? Thanks for the advice.
!!!!! HELP - CARBURETOR LEAKING & FUEL TANK NEEDS TO BE CLEANED!!!!!!!!!!!!!!!!!!!!! islandman Engine 3 03-17-2007 03:36 PM
Permatex epoxy (all metal) gas tank. 1Fast65Elky Hotrodders' Lounge 8 10-03-2006 02:00 PM
POR-15 gas tank resto kit cruzinTLT Body - Exterior 1 06-06-2006 05:08 PM
Gas Tank 1970 Chevy Camero kan Engine 0 05-21-2006 11:57 AM
gas tank in Model A pcoghlan General Rodding Tech 17 03-29-2006 10:05 AM
