I learned about it over on the HAMB. I'll try to answer some of the questions posed here...................
,Someone say rum???? And the Coke has the phosphoric acid in it but this way seems much easier than the way I do it ...I can sit in the lounge chair drinking my rum and coke and just watch ....maybe get one of those big umbrellas so I dont get sunburned....
Jim |
I don't know what the chemical makeup of my molasses was. I just know it was 'feed grade' and I bought it at a commercial livestock feed store. I left my stuff in the mix for 2 weeks and it completely removed 80 years of severe rust.
This thread knocked over one of "my"
Kenny |
Well
Have you ever seen a Cow that ate Molasses get a Rusty Stomach??? There yah go
I was able to get the molasses to work. I guess it just takes time. Some of the metal took 2+ weeks. I noticed on some of it the metal actually started turning black. Anybody seen this before?
The black may be iron oxide, it is the same coating that many bolts on a vehicle have. It is a protectant, but not a very good one. If so, Just clean the piece properly and coat with epoxy. No need to worry about the black parts, it will hold paint just as well as the rest of the part. I read on the web somewhere a while back when I was first researching chelation I read where a guy suggested finding a used chest type freezer and using it as a soak tank for chelation soaking. Just build a rack in the bottom to support your items and not have them poke holes in the interior. When I get to that point on my current project there will be an old chest type freezer along side the shop. I am going to try and find one with a built in drain valve. |
Very interesting read (and look), thanks for posting. I am not big on "home remedies" but damn that's intresting.
And because I am an anal nut job I have to say that isn't a 27, it's a 26. At least the doors are. ![]() Brian |
Ive been using some stuff from the local supermarket simply because I havent found any feed stores that sell the stuff. I think it works well enough to warrant finding feed grade in bulk and going to the next step......Steve
| Electronic miracle rust cure? | ScotY | Body - Exterior | 8 | 11-11-2008 03:04 PM |
| Rust Removal | sgo70 | Body - Exterior | 3 | 08-28-2008 04:45 PM |
| Rust removal with molasses - it works! | baddbob | Body - Exterior | 2 | 01-22-2006 09:57 AM |
| rust removal | pillsbery | Body - Exterior | 1 | 06-27-2004 02:02 PM |
| Rust removal? | bowtieorbust | Body - Exterior | 7 | 09-14-2003 06:16 PM |
