Rust removal...........the miracle of molasses!
This is what I had to work with. A rusty/rotted mess! The PO found it 10' off the ground nesting in a tree that had grown up under it!
![]() ![]() After a couple of weeks in a molasses bath the transformation is incredible! ![]() ![]() You'll notice rust on the lower 6" or so. That's because the first time I tried it, my pond liner had a leak and most of the molasses drained out. So, I left it in and it dissolved the rust on the first 6". Got a new liner and flipped the panels over. The rusty part was originally clean but stuck out and was exposed to air. It's only surface rust that'll come off with a light sandblasting (as will the flash rust that begins forming almost immediately). First run with the doors (notice no harm to original paint, rubber or pot metal)............. ![]() ![]() Built a 4'x4' box out of scrap 2x4's and OSB............. ![]() Installed a reclaimed pond liner from an old pond in our backyard............... ![]() Proof positive that an entire '27 Model T roadster will fit in a 4'x4' box.......... ![]() 20 gallons of molasses bought at a local feed store for $60 including tax, then mixed with water at a 7:1 ratio - 7 parts water to 1 part molasses............ ![]() Entire car submerged in the brew (until most of it leaked out)!............. ![]() Replaced the liner, added some more molasses and after two weeks............wah lah! Yeah.......it works!!
well i'll be dang. looks purdy good too. i never heard of usin moleazzes for demovin rust.it mite be a bit sticky but it wont hurt anything or you.how long will that mix last or take off rust?
SWEET
.....How long did it take?????
I love these "homegrown" methods...kind of makes my dad's "****-a-mamie" stories of things they did in the "old" day seem more credible..Yes, I know not ALL of the old ways were safe or smart, I'm just sayin'........
Hi evintho,
theres a trick to remove rust on smaller spots, good for detailing-- Alu foil and regular cola -- wad up a about foot long strip of da alu foil - then pour da coke on it and rub da spots with a circular motion, when down to no rust rinse with water, let it dry good, a hair dryer works good, then primer asap -- it doesnt get seams real good but an alu or brass brush gets that pretty good. Great Dip! was is sugar cane molasses, or sugar beet molasses? Balder |
you can set a car out in west texas for a few weeks and it will be blasted when you come back...
Shine, only a guy that lived in Big Spring can appreciate that. Goes for windshields also.
Trees |
never buy stainless from west texas without seeing it . sand storms ply hell with shiny stuff.
here is the link: http://www.google.com/search?sourcei...n+rust+removal how it works: http://www.westerhuis-restauratie.nl...ing-agents.pdf |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Electronic miracle rust cure? | ScotY | Body - Exterior | 8 | 11-11-2008 03:04 PM |
| Rust Removal | sgo70 | Body - Exterior | 3 | 08-28-2008 04:45 PM |
| Rust removal with molasses - it works! | baddbob | Body - Exterior | 2 | 01-22-2006 09:57 AM |
| rust removal | pillsbery | Body - Exterior | 1 | 06-27-2004 02:02 PM |
| Rust removal? | bowtieorbust | Body - Exterior | 7 | 09-14-2003 06:16 PM |
