Just my two cents worth on por 15. I've had very good results with it. I don't know how you got it off so easily. I havn't found any stripper that will cut it. I've even used a scailler to try and remove it. I don't use the prep stuff. Right out of the can works best for me.
Hold on there Billyzz, Nobody is criticizing anybody! I just find it interesting how other people deal with rust! And believe me, the more that I get into my project, the more I am on a budget! When I started , I was going to do a small rust repair at the bottom of the rear window! Now the whole car is bare metal. What a can of worms! Every day I ask myself if I've gone too far?
After the Paint and all is loose it gets power washed and then it goes in the phosphoric acid bath (very similar to ospho) but the problem is that they heat it so it works quicker, but then a quick dip doesn't get all the rust off. So when I get it home I use the phosphoric acid and a wire brush to finish it. The stripper charges $30 for a door. I like the electrolysis a lot better because they get it all, but the price is $85 for a door. After its cleaned and rinsed I put a scratch pattern on it, W&G it, then tape all the holes and pour SPI epoxy in and roll the door around. I left enough in the bottom to seal the seam.
Gringo, I used Jasco paint remover and within 60 seconds, the Por15 was blistering and bubbling! Maybe youre on to something, just paint it on without the marine clean and metal ready? Don't get me wrong, I'm not saying that it should resist paint removers. All I know is it didn't stop the rust on my car so I took it ALL OFF and I'm now 100% free of Por15. I might try some of whats left on my shovel or my lawnmower, but never again on my car! No way!
I am restoring a Firebird. I used the pressurized blaster from Harbor Freight on everything. It works great after I replaced the valve with an ALC unit. I replaced the manifold with an ordinary t-pipe.
On all the seams and areas where metal was hidden I took the time to drill or break every spot weld. You will be amazed how much rust is just sitting under what people claim to be a "rust free" car. My Firebird was and is still partially like this. I then epoxy primered all the pieces(So far hood, Fenders, trunk lid) and then welded them back together with my stick welder.(not the best choice in welding) I used eastwood anti rust to fill in all the seams and under parts. I tried wire wheels, naval Jelly, etc. Nothing cleans as well or as fast as a pressure blaster(those siphon ones don't count) Some complain it makes a mess. It don't matter I don't mind vacuuming the media off my garage floor and sifting it through a screen. |
| Rust Removal | sgo70 | Body - Exterior | 3 | 08-28-2008 04:45 PM |
| Paint removal options? | Gearhead forever | Body - Exterior | 2 | 07-02-2005 06:21 PM |
| rust removal | pillsbery | Body - Exterior | 1 | 06-27-2004 02:02 PM |
| Rust removal? | bowtieorbust | Body - Exterior | 7 | 09-14-2003 06:16 PM |
| Rust removal | 35 chevy | Body - Exterior | 1 | 10-30-2002 07:24 PM |
