Rust Removal Tips
Yes I searched, Yes I read the Wiki entry on rust.
I am posting this message because I would like some advice specific to my situation. First off you can view my project journal if you want to see all the progress. I have cut out the section of sheetmetal that were heavily rotted. So this i s where I stand as of Today. I have hit the entire area with a wire brush and een an abrasive wheel where I could. I am stuck with a bunch of tight corners. I used the wire brush tool for my Dremel but that didn't really clean the rust up. As you can see. There are some tight areas where a large wire brush can't get into, and a small wire brush just falls apart.So my question is, how the hell can I get this rust knocked off enough to spray on? Next, My buddy told me that I could use some Rustoleum paint diluted with 15% acetone to seal the rust. This would be a subsitute to the Por15 stuff. Another area of concern is here: But I am buying a patch panel and I believe the major of this rust will be removed when I install the new patch panel. I would still like some advice on removing this rust incase the patch panel doesn't cut it. Thank you for your time. -Todd |
do you have aircompressior ? try one of the small spot blasters. the one i have looks like a spray gun , i got it at tractor supply. it does a nice job for small projects.
Here is the thread where I was discussing abrasive blaster uses: Abrasive Blaster |
yes the media does go everywhere.........heres what i was talking about useing and its still best to be used outside.....but i did use mine on a couple tight areas inside and cleaned up the mess after........
I can roll the car outside to an extent, but I would prefer not to... |
Im still looking for some tips |
Hope it helps, had a thought after I signed off. A perfect thing for the plastic; a cheap, clear shower curtain from a big box store, trim to suit. The trick is just to contain the sand for reuse and to keep it from bouncing back in your face.
If you go down this root, the real trick is just to improvise. My box looks nothing like it did when I started. Be interesting to see what others come up with, I got a rust bucket I need to attack one day. Regards PK |
Thanks for your words of wisdom. It really helps. You gave me a ton of ideas. Im going to fold up some scrap metal, or even some cardboard and make a pyramid type sheifl to go around the nozzle. I am hoping this will help keep dust out of my face. I will then put a long and somewhat wide plastic container under the car in the area where I am blasting. This will work well for the area picture, because Im going to cut out the sheet metal on the body. On the opposite side I am going to try and use a wet dry vacuum to suck up the media and hopefully reuse most of it. |
I'll pm you.I got a sure cure.
Pretty clever idea. You could attach your shop vac directly into it. You will want to reuse that sand.You could blow through $10 worth of aluminum oxide on a square foot. could
Depending on hoe big your cone is, remember that the spray pattern is pretty focused, figure you'll be hitting a spot about the size of a quarter so you need to be able see to aim it. You might want to put a widow in your pyramid...a light to if you can (really makes a dif. the bright er the better. Regards, PK |
I bought a spot blaster that had the media comming out the middle and the vac on the outside edge it was great for trim hole rust not messy at all...
| Electrolytic rust removal revisited | willys36@aol.com | General Rodding Tech | 14 | 10-16-2009 07:45 AM |
| parts cleaning and rust removal | helrazr3 | General Rodding Tech | 6 | 04-09-2007 02:37 PM |
| Electro-chemical rust removal | hendershot | Body - Exterior | 6 | 05-19-2005 01:56 PM |
| Rust removal oops. | Wmarden | Body - Exterior | 2 | 12-29-2003 11:33 PM |
| Rust removal | 35 chevy | Body - Exterior | 1 | 10-30-2002 07:24 PM |
