rust removing and coating - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2005, 06:40 PM
Last journal entry: dash mods
I have my 38 Chev sedan disasembled.This was a running original car in pretty decent shape.Car is in paint and any rust underneath looks like faint surface rust.I want to clean the chassis, probably sandblast.I want to sand by hand and maybe acid clean any pitting that may be left on the bottom of the floor(underneath car).Too hard to move car body to blast.Does this sound like a good idea?
Also I was going to POR15 the chassis and under the car.Would epoxy primer be better.I'd have to brush it on as I have no compressor yet.I just can't buy that POR can be used over rust either.I haven't done much body work, but I've seen how rust travels under paint and just can't see coating it as the same as ridding it.
Merry Christmas, Cisco
Old 12-15-2005, 07:21 AM
MI2600's Avatar
Member# 3287
The thing I like about POR-15 is that even with a brush application it flows and you don't see brush strokes. I use two coats, per the instructions, and I haven't had any problems yet.
Old 12-15-2005, 01:58 PM
Tazz
Amazing stuff that POR-15..and it works too!!
I would clean off the loose rust and cover the rest. It seals and there-for does not allow the rust to continue rusting..no oxygen..no rust!!! Great stuff on inside panels and on frames!! Any rust morf or etching acid will seal the rust after grinding or wire wheeling off the loose stuff. Brush on the POR-15 and then apply sealer primer and then sand-able primer then paint if you want to or just leave the POR-15 finish without any other paint. Rust does NOT come back...great stuff!! Please...PLEASE remember to cover your skin, this stuff does not come off!! I have had some success with "goo gone" but nothing gets it all off!!
Tazz
Old 12-18-2005, 02:21 PM
Your statement here tells me you are wise beyond your years.
For lightly rusted panels Phosphoric acid mixtures are sold through auto body supply houses are excellent for cleaning all the rust off. I use a coarse scotch brite pad that I wet with the solution and scrub the panel to clean shiny metal. One brand sold is Rust Mort. Just look at the labels of metal preps and either the first or second ingredient will be Phosphoric acid. Clean shiny metal won't rust under paint. Rusty metal will.
I do a lot of body restoration and am currently REDOING a POR'ed vehicle. It's not the first time and it won't be the last.
Nothing in a wet spray beats epoxy primer. For your frame your best bet is to sandblast or dip and either powder coat or epoxy primer.
Mustang II Control Arms - Removing Bushings PICS djjc76 Suspension - Brakes - Steering 1 05-14-2005 04:19 PM
Frame prep. and coating on 89' chevy p/u Hazard Body - Exterior 3 03-27-2005 07:46 AM
Best Rust Inhibitor? bigbrowndog Body - Exterior 45 11-21-2004 08:26 PM
Removing anodized aluminum coating Kermitt47 Body - Exterior 2 10-17-2004 03:17 PM
Removing a coating 1961_MGA Body - Exterior 2 09-16-2003 01:15 AM
