rust in seams - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2011, 07:59 PM
mitmaks's Avatar
Last journal entry: Grille
rust in seams
I have some rust in seams where door skin is wrapped around door frame. How do I treat this area?
I think I'll remove factory seam sealer, use wire brush on drill to get rust off, epoxy prime/seal, seam seal and paint. Is this right approach?
Old 09-08-2011, 08:09 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Use a wire wheel cup on a grinder instead of a drill motor, it makes it easier to get into the seam. You could use a rust converter spray from POR15 to get any rust you miss.
Old 09-09-2011, 02:56 PM
Be sure to clean and seal the pinch on the inside of the door cavity too. make sure you don't plug up the door drain holes though.
Old 09-09-2011, 08:19 PM
willowbilly3's Avatar
Last journal entry: Body mods
You can never get it all, it will come back.
Old 09-11-2011, 06:42 AM
deadbodyman's Avatar
Wiki Edits: 11
yeah to get it all you would have to seperate the two,clean and epoxy both pieces then reassemble.
how to get rid of rust in the seams? glhx Body - Exterior 1 05-27-2009 05:29 PM
D-rust it, Safest rust remover, Evapo rust. 35prog Body - Exterior 21 05-02-2009 02:56 PM
rust between spotwelded seams 57halfton Body - Exterior 7 06-16-2008 04:25 PM
Rust in folded seams jesuscowboy Body - Exterior 4 05-26-2008 10:36 PM
Fixing rust between seams modas Body - Exterior 2 03-28-2006 08:11 AM
