Rust Spot In Back Fender Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2006, 07:40 AM
AMERICAN MUSCLE!!!!!!!!!
Hello got a 67 camaro. it has a rust spot on rear drivers side fender. its not all the way through the metal there is 2 sides to it but the outside is rusted but not through the metal. what would i use to fill it in. i dont have a welder and not alot of money in my pocket what do i go thanks....Allen
Old 01-16-2006, 07:48 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
In that event
While it may not be absolutely "correct" one can take a wire brush and get all the rust out one can get to..then use some epoxy primer in there and then some high build primer to get it to smooth..I am taking it that this is primarily some surface sort of rust which has bubbled the old paint, and that there is still solid metal there..
If you are doing a "preservation job" rather than a complete restore just concentrate on the rusty spots and leave it alone where the paint is still good..
OMT
Old 01-16-2006, 07:50 AM
should i use bondo to fill it in. Allen
Old 01-16-2006, 07:54 AM
Wiki Edits: 3
Once the metal is cleaned and primed then a wee bit of bondo is fine..If you have a hole there you may wish to consider bonding a piece of metal to the back side with one of the new panel bonding adhesives..then bondo the hole area..
OMT
Old 01-16-2006, 07:59 AM
roger1's Avatar
You need to make sure this rust is not from the inside out. These camaros are prone do doing just that. I know you say it's not all the way through but it may just appear that way.
You say rear driver's side fender. (Rear fender is normally called a quarter panel.)
Is that rust at the edge of the quarter panel near the wheel well? This is where rust normally begins in these cars because it is where the outer panel meets the inner panel and it is a trap for moisture.
Old 01-16-2006, 08:17 AM
The rust is at the bottom wear all the trash,rain etc got on it from the wheel spinning. isn't that bad looking just needs to be fixed. thank you all...Allen
04 mustang rust oldred Body - Exterior 3 07-19-2005 07:15 AM
What I SHOULD have done... Fender Purchase billg_69gmc Body - Exterior 6 07-11-2004 09:09 PM
wider back fender 49olds Body - Exterior 0 07-04-2004 08:03 PM
Metalshaping/Panel Relacement '34 Chrysler fender Randy Ferguson Body - Exterior 12 05-31-2004 10:37 PM
