rust under paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2005, 10:26 AM
New Member
rust under paint
I'm getting ready to attempt my own body work on my chevelle wagon. I have been reading some of the postings under this section and and have gotten the basics but have one question before I start. Most of the postings say to apply sealer primer before starting the filling. My car has the original paint and is a west coast car. The finish is very rough and I am told that this is rust under the now thin paint. Do I sand to bare metal first or how do I get started?
Old 10-18-2005, 02:02 PM
Wiki Edits: 49
You have to sand the sections where you suspect rust down to the bare metal. That's the only way to make sure you get rid of the rust. Then coat the area with a good quality epoxy primer to seal the bare metal from moisture and provide a good surface for body filler. If the finish is as rough as you say then you might think about taking the whole car down to bare metal so your new paint job will have a good surface to adhere to.
The only correct way to fill rust holes if you have them is to weld in a patch panel. Trying to fill them with body filler will only work temporarily and you won't be satisfied with the results.
Old 10-18-2005, 02:53 PM
BarryK's Avatar
Like Centerline said and if I can add one thing, the rust under paint is because there is lacquer on the car and that what lacquer causes as it breaks down.
Car MUST be stripped or wasting your time.
Old 10-18-2005, 04:39 PM
Yep, strip to baremetal is what you should do. After you have done all the hard work making it right, I suggest you clean it often as well as wash underneath, wheelwells, keep mud and dirt from packing in corners. Being in the midwest, its a constant battle fighting rust. Hopefully it will stay away from the salt trucks in the winter.
Old 10-19-2005, 10:51 AM
New Member
thank you for the help
next Friday, the 28th is my last day of work. I'm retiring from ford motor, then it is just me and my chevelle. I cant wait to get started on the body.thanks again to all of you for your help
Old 10-19-2005, 10:55 AM
Congradulations on the retirement! I hope I can afford to do that someday. After all those years at Ford you're going to spend some quality time with the Chev you love.....I like that.
Check out SPI (Southern Polyurethanes Inc.) for your epoxy primer, primer surfacer and clears. I've been using many different epoxies for many years now and recently started using/testing SPI, In my opinion it looks to be the best bare metal primer available.
RUST..What are the acceptable permanent ways to get rid of it? Rocket1 Body - Exterior 213 10-30-2011 06:23 AM
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 12:33 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
This is interesting. Temporary peel off paint. kenseth17 Body - Exterior 5 08-11-2005 09:41 PM
Prodedure to paint over Zero Rust? unioncreek Body - Exterior 1 01-27-2004 11:42 AM
