Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - RUST..What are the acceptable permanent ways to get rid of it?
  #200 (permalink)
Old 08-01-2010, 09:40 AM
stephen44 stephen44 is offline
ok - so I've read everything there is on rust removal - including every posts in this thread - and think I understand the pro's and cons...but there is one thing I don't get....
Rust needs a few things to "grow" - i.e. continue the rusting process .. iron + oxygen + water ..
so if i wire brush off the rust surface so i am left with pitted bright metal - with admittedly rust down in the pits - but no holes or very thin metal - but then epoxy both sides therefore creating a barrier to oxygen and water - won't the rust just stop at this point ?
then fill - then epoxy again - so even if the filler absorbs some moisture it is sandwiched between two epoxy layers - am I not good.
(now this is for a daily driver resto - not a show winning car )
- Stephen
